ford 3000 snow blower
   / ford 3000 snow blower #1
trentonford3000
glencoe mn
ford 3000
I am starting a thread that i have never found. what size snow blower should i run on a ford 3000 it is an 8 speed two stage clutch. There will be alot of drifts for it so i dont know what is better a single auger (large) a single auger (small) or a dual auger. Forum are some with teeth and some with just a regular spiral. The tractor has around 45 hp i believe and is 74" wide. What has worked for you guys in the past?
   / ford 3000 snow blower #2
Snow blowers eat HP. I would not go beyond 60", (72" in good conditions).
Your 3000 is rated between 38 - 40 PTO HP depending upon vintage, transmission and fuel.
SDT
   / ford 3000 snow blower #3
If your tractor is 74" wide the 72" would be border line on clearing a path especially if you are turning corners. 60" would just be an ongoing irritation since your rear tires would always be running into the snow banks. I had a dual auger 96" that I used with a Ford 5600 Diesel. In deep snow you had to feather the clutch at times but it got the job done.
it is a gas with an 8 speed. The driveway is strait. My uncle runs a 8 foot on a wd but he doesn't have enough power to throw it. he actually found a 6 foot with a big single auger not in the greatest shape for $600 will this blower work for drifts? he advised me to not go as big as a 7 foot is he correct ? the tractor is 72 inches wide but the tire chains add another two inches
   / ford 3000 snow blower #5
Your tractor has two reverse gears. One too slow, the other too fast. A cheap 6' blower is a very good start to see if you want to run a blower with that tractor. You probably don't. I have a 74" blower that I used a couple times on a Ford 4000 with the same 8 speed transmission and a few more HP. Not good. I now use it on a Case 885 which has about 10 less HP and 2 more reverse choices. Much better. 42 PTO HP and a six foot blower is a pretty good match until the snow gets really deep, then it's a load.
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2007 Jeep Liberty (A50515)
2007 Jeep Liberty...
2020 Kia Sportage SUV (A50324)
2020 Kia Sportage...
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
