Tractor Sizing Want a YM 1610D Short Block
   / Want a YM 1610D Short Block
How much would a 1610d engine go for?
   / Want a YM 1610D Short Block #12
What part of Texas are you from? I live in the Gilmer area. I read back over some of your posts and know the engine was siezed and you had the head off at one time. Have you concluded it is not repairable? If repairable, likely to be much cheaper then a replacement.
Putting this ebay page here just to shown prices could vary big time. Did you contact Bruce that said he had one? yanmar engine | eBay
After a little research I thinking the 1610 (3t75u) doesn't have sleeves. Is that correct?
   / Want a YM 1610D Short Block #13
Forget the WD40. Pull the injectors if you can get them out and pour in Kroil, or a 50/50 mix of ATF & acetone or MEK. Looks like you've had the head off once as per the last post (above) if so you should know how to do it again. If you can get the head off, it would be better. Either one of the above will cut through the rust if that's what the problem is. If in fact, it has a hydro lock due to water in a cylinder, removing the head or the injectors will relieve that. I wouldn't want to live without Kroil!!!
   / Want a YM 1610D Short Block #14
   / Want a YM 1610D Short Block #15
A replacement engine would probably equal the cost of a replacement tractor. Those cylinders are a mess. Pistons need to be knocked out, cylinders honed, and probably oversized pistons installed.
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
Portable Drain Tank (A56860)
Portable Drain...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
Kubota T1700X OHV Riding Mower (A57453)
Kubota T1700X OHV...
