Tractor Sizing Want a YM 1610D Short Block
   / Want a YM 1610D Short Block
How much would a 1610d engine go for?
   / Want a YM 1610D Short Block #12
What part of Texas are you from? I live in the Gilmer area. I read back over some of your posts and know the engine was siezed and you had the head off at one time. Have you concluded it is not repairable? If repairable, likely to be much cheaper then a replacement.
Putting this ebay page here just to shown prices could vary big time. Did you contact Bruce that said he had one? yanmar engine | eBay
After a little research I thinking the 1610 (3t75u) doesn't have sleeves. Is that correct?
   / Want a YM 1610D Short Block #13
Forget the WD40. Pull the injectors if you can get them out and pour in Kroil, or a 50/50 mix of ATF & acetone or MEK. Looks like you've had the head off once as per the last post (above) if so you should know how to do it again. If you can get the head off, it would be better. Either one of the above will cut through the rust if that's what the problem is. If in fact, it has a hydro lock due to water in a cylinder, removing the head or the injectors will relieve that. I wouldn't want to live without Kroil!!!
   / Want a YM 1610D Short Block #14
   / Want a YM 1610D Short Block #15
A replacement engine would probably equal the cost of a replacement tractor. Those cylinders are a mess. Pistons need to be knocked out, cylinders honed, and probably oversized pistons installed.
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
bad boy zero turn 72 (A56859)
bad boy zero turn...
MULCHER (A58214)
MULCHER (A58214)
Milwaukee Electric Tools Sign (A57454)
Milwaukee Electric...
12ft. S/A Utility Trailer (A56859)
12ft. S/A Utility...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
