Studding pickup truck tires need info asap
   / Studding pickup truck tires need info asap #21
Finally, the voice of experience and reason. Thank you
   / Studding pickup truck tires need info asap #22
And it's state law you run 4 studded tires here in Maine, but the only time you get hassled is if a vehicle inspection is due in the winter months. But this came about with the proliferation on front wheel drive vehicles, no weight on the back axle and they will tend to slide around on you. That got blamed for accidents and the ins co and tire lobbies pushed it. God forbid you get blamed for driv9ing too fast for conditions, which I might be accused of from time to time. A rear wheel 1/2 ton?? Stud them rears and ride. (That sounds kinda bad). We usually have an extra set of rims for our snows. I do like the extra traction of all 4 corners, plus I will throw 120lbs of sand over the rear axle too. When i am in my minivan I can give about any 4 heel drive a good run for their money in the snow. If it gets too deep and causes me clearance problems, thats where they get me....did I mention i might drive too fast for conditions? ;)
   / Studding pickup truck tires need info asap #23
And it's state law you run 4 studded tires here in Maine... But this came about with the proliferation on front wheel drive vehicles, no weight on the back axle and they will tend to slide around on you. That got blamed for accidents and the ins co and tire lobbies pushed it. God forbid you get blamed for driv9ing too fast for conditions, which I might be accused of from time to time. A rear wheel 1/2 ton?? Stud them rears and ride....
You got it, it came about with the proliferation of front wheel drive and the push by tire and insurance companies. The tire companies always want to sell and install 4 identical tires. What do you do if your tires are 25% worn out and a broken bottle goes thru a sidewall, do you throw the other 3 tires out or try to sell them on Craigs's List?
It's important to note that the Maine tire stud law only applies to front wheel drive vehicles, not RWD like the OP's 1/2 ton pickup:MRSA Title 29A, Chapter 15, Inspection and Repair 16222, Chapter 1 Section 170 page 26, 10. STEERING, ALIGNMENT, AND SUSPENSION K. Tires and Wheels (i) Reject vehicle if it is a front wheel drive vehicle with studded tires only on the front.
I think for a few years the Maine law applied to all vehicles, but there were so many complaints about enforcing it on RWD that it was changed to the way it reads in the current version.
   / Studding pickup truck tires need info asap #24
I have a 97 f150 long bed 2 wd open differential. You guys helped me out with figuring out how to get more traction. I have 300 pounds of weight over my axle now and that helped a lot as I have light duty suspention.
I found out it IS legal to stud your tires here. WHere can I get them done? Will it hurt to run tires on 20 mile trips of pavement? Can I have my current drive tires studded then remove them in march? Next year I plan on buying two snow tires and leaving them studded. we are getting an ice storm this way and people don't know how to drive. Any information on studding my tires would be helpful. I grew up with tire chains on the tractor I figure studs and weight in the back will make quite a difference
First thing to do is find two rims for the rear and mount new studded tires on them.Much simpler year after year to deal with.You'll have greatly improved traction and stopping will be much better also.A few hundred pounds of sand in the bed helps a lot too.
. Thank you I have 240 pounds of sand bags and 50 pounds of salt all in the bed of my pickup (sealed not laying in the bed). I also have two rims that fit my truck. One is my spare tire the other is another spare. I would find it easy to get two tires brand new and studded next year. When spring is here I will remount my normal tires on the rear
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
UNUSED JCT 55" HYD CONCRETE MIXER (A57193)
UNUSED JCT 55" HYD...
2010 Ford F150 (A55973)
2010 Ford F150...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55852)
2021 Delta...
JOHN DEERE 6130M TRACTOR (A57192)
JOHN DEERE 6130M...
2022 Polaris Ranger 4x4 Utility Cart (A55851)
2022 Polaris...
