Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #491
The new trucks come with full inner liners in the rear wheelwells. We shall see if it makes a difference. It very well could make it worse as we know.
can only speak for my 03-3500 and father in laws 1996-1500 -both ordered with the inner wells . neither showing any rust problems . both trucks driven on calcium chloride treated roads??
   / Ram1500 EcoDiesel V6 revealed! #492
Basic thermo laws - energy converted in an IC engine is proportional to compression ratio.....
The USA centric "problems" with diesel engines centre around Taxation, EPA psychosis and perpetual expansion, Oil company investments in Govt, and un-negotiated trade barriers; to name a few reasons..... none of which have much (more like anything) to do with efficient use of energy.
Also, if the IC engine had been invented 100 years later, the 2 Safety issues I highlighted below would have probably ensured that Gasoline would have been quickly litigated out of existence.
Rgds, D.
Diesel engine - Wikipedia, the free encyclopedia
The diesel engine has the highest thermal efficiency of any standard internal or external combustion engine due to its very high compression ratio.
Major advantages
Diesel engines have several advantages over other internal combustion engines:
They burn less fuel than a petrol engine performing the same work, due to the engine's higher temperature of combustion and greater expansion ratio.[1] Gasoline engines are typically 30% efficient while diesel engines can convert over 45% of the fuel energy into mechanical energy[32] (see Carnot cycle for further explanation).
They have no high voltage electrical ignition system, resulting in high reliability and easy adaptation to damp environments. The absence of coils, spark plug wires, etc., also eliminates a source of radio frequency emissions which can interfere with navigation and communication equipment, which is especially important in marine and aircraft applications.
The life of a diesel engine is generally about twice as long as that of a petrol engine[33][better source needed] due to the increased strength of parts used. Diesel fuel has better lubrication properties than petrol as well.
Diesel fuel is distilled directly from petroleum. Distillation yields some gasoline, but the yield would be inadequate without catalytic reforming, which is a more costly process.
Diesel fuel is considered safer than petrol in many applications. Although diesel fuel will burn in open air using a wick, it will not explode and does not release a large amount of flammable vapor. The low vapor pressure of diesel is especially advantageous in marine applications, where the accumulation of explosive fuel-air mixtures is a particular hazard. For the same reason, diesel engines are immune to vapor lock.
For any given partial load the fuel efficiency (mass burned per energy produced) of a diesel engine remains nearly constant, as opposed to petrol and turbine engines which use proportionally more fuel with partial power outputs.[34][35][36][37]
They generate less waste heat in cooling and exhaust.[1]
Diesel engines can accept super- or turbo-charging pressure without any natural limit, constrained only by the strength of engine components. This is unlike petrol engines, which inevitably suffer detonation at higher pressure.
The carbon monoxide content of the exhaust is minimal, therefore diesel engines are used in underground mines.[38]
Biodiesel is an easily synthesized, non-petroleum-based fuel (through transesterification) which can run directly in many diesel engines, while gasoline engines either need adaptation to run synthetic fuels or else use them as an additive to gasoline (e.g., ethanol added to gasohol).
You info is both dated and partly incorrect.
When was the last time you seen a gasser with a distributer ignition ?
It's not about compression ratio . It's about expansion ratio and brake mean effective pressure. Ever consider the energy required to compress the combustion chamber pressure to 750-1500psi instead of to 75 to 250psi?
Your dated info fails to mention the difference in price between gasoline and diesel per btu of energy.
If diesel refining was so cheap and simple. Why does diesel run 20% more than gasoline at the pump?
Simple diesel fuel system ? The reliable Bosch P pump and it's brethren have not seen light highway use since the early 2000's . Ever price common rail diesel injectors , pressure pumps and lift pumps?
Have you not seen turbo charging on the Ford Eco-boost without requiring race gasoline?
Have you not noticed the out of touch , man and machine hating eco thugs in the EPA. They have mandated the need for common rail injection, variable vane turbos. Urea injection. Particulate filters and soot burners. Cooled EGR systems.
Then there is the diesel fuel gelling in winter and algae in the summer.
Ever price the difference between a gasser and diesel oil plus all filters being changed?
Sorry but you are going to have to give up the yesterdays of diesels from 12-25 years ago.
   / Ram1500 EcoDiesel V6 revealed! #493
Because the crude we refine here is full of sulfur and not as easily extracted as the stuff the euro market is supplied with. The price of gasoline is also kept artificially lower in the US than the rest of the world.
   / Ram1500 EcoDiesel V6 revealed! #494
The engine is nice and all....
But has Dodge figured out how to build a pickup that wont have the rear wheel arches blistered and rotting out after a few years? Seems almost every Dodge pickup I see that is over 4 or 5 years old is showing blisters over the rear wheels.. Whats up with that???
Prolly will figure it out about the same time Ford figures out how to keep the rear cab corners form doing the same thing..
   / Ram1500 EcoDiesel V6 revealed! #495
They did...they went aluminum. ;)
   / Ram1500 EcoDiesel V6 revealed! #498
I thought AL wasn't exactly great with road salt either? What's the point of that? Why not SS?
A little while ago a friend was using his bosses 08 Duramax. He was strapping something down and had to move the truck. A strap got caught under the wheel and just totaly collapsed the side of the bed!
These arn't trucks anymore! Nothing more than a soup can!
   / Ram1500 EcoDiesel V6 revealed! #499
The alloy Ford is using will do fine with salt.
How expensive is SS compared to Al? How heavy is it? The primary reason for Al is weight savings.
   / Ram1500 EcoDiesel V6 revealed! #500
UNUSED FUTURE 17" EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 17"...
Heavy Duty Wheel Balancer Machine (A55852)
Heavy Duty Wheel...
2023 CATERPILLAR 420 BACKHOE (A52707)
2023 CATERPILLAR...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
2015 Ford F-750 Stellar 10628 10,000LB 5 Ton Mechanics Crane Truck (A55852)
2015 Ford F-750...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
