Thanks Dave. I put the starter back together and installed it but I don't even get a click when I turn the key. New starter, new battery and new cables....You will see in the photos that I put the small red wire from the tractor on the same post as the positive cable coming from the battery (not sure this is correct) Any help diagnosing this "lack of power" would be much appreciated. Thanks!
View attachment 358685View attachment 358686View attachment 358687View attachment 358688
Since the starter is not spinning, something is not correct. Can you tell me what exactly is new. Is it just the solenoid? The starter does not look new so I am wondering did the copper bars come with the solenoid ? Without being able to touch things with my multimeter, I am puzzled by the two electrical connections on or from the body of the starter. One being the braided insulated copper wire with the ring terminal on the end of it and the second being the insulated stud where you have the copper bar connected. Is there a brand name on the starter, perhaps Lucas.I took the starter off and tested it on the bench by hooking it up as you instructed. When I make the connection, the part of the starter with the teeth extends clear out but does not spin..View attachment 359303View attachment 359304
Do I have something wired incorrectly?
Hi Dave
Here is the rest of the story.....the tractor hasn't started well for some time and a few months back it wouldn't start at all so I decided to replace the old parts since nothing had been touched for many years. I replaced the cables, battery and starter. Unfortunately the day I did it was very cold and since I was having trouble even feeling my fingers I managed to strip most of the copper studs when bolting on the wires and therefore didn't get a good connection. I took the starter off and then worked on the solenoid but couldn't get it apart to replace the studs so I bought a new solenoid on ebay. I normally take pictures before removing things but this time I didn't so I just did the best I could to rewire things...obviously incorrectly. Thanks for your help. View attachment 359416View attachment 359417View attachment 359418
Is there an easy way to bypass the solenoid and bench test the starter directly?
I took the picture of your starter to a guy who has a business repairing starters and alternators. He explained that your solenoid is a two stage one. For example, if the starter gear did not engage with the flywheel gear when you turned the key to start, the solenoid would apply power to the braided wire which supplies one field coil. This would cause the starter to rotate slightly so that the gears could mesh. The action of the gear extending fully allows the hardware inside the solenoid to complete the circuit to supply power to the insulated stud connected with the copper bar. This powers all the field coils and the starter rotates with full power.I hooked it back up and tested both terminals (with the copper bar going to the insulated stud and with the braided wire connected to it) and I get power to each of them - used a light tester I just picked up at Canadian Tire.
