NH 640 baler or JD 335
   / NH 640 baler or JD 335 #11
Rick
I guess those type balers are all right for someone that bales just a few bales a year but not for me. I like being able to bale 30+ bales per hr(depending on the thickness of the hay) and that ain't happening very easy with a manual tying machine. There's a Big difference in baling a couple hundred bales a year and several 1000 a yr. Then one throws in the speed of netwrap and that will spoil the baler operator.
I agree, but I do still have a 335 baler and have baled a lot of hay with it. About the most I ever got was around 130 bales a day. I can also speak to the "crick in the neck". I finally installed a mirror in the cab to watch the slides and adjusted the remote speed down which helped.
We just keep it as a back up baler now. My son cut his teeth on the 467 with auto tie and a monitor, so I still like to pull the old 335 out and show him what baling was like back when you had to drive the tractor.
   / NH 640 baler or JD 335 #12
I think the JD 467 is the BEST & easiest baler I've run. I'm on my 2nd 467. 1st 467 had 30,000 bales on it when I traded to get Netwrap & the 2nd 467 has 17,000+ bales on it. I also like the Mega-wide pickup which negates the need for converging wheels.
2011 Kubota L3200 (A50123)
2011 Kubota L3200...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2007 Allmand Night-Lite Pro Towable Light Tower (A51691)
2007 Allmand...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
1985 Ford Ltl9000 Tender Truck (A53473)
1985 Ford Ltl9000...
