sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,265
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Not sure about the newer ones, but my '96 2500 with dana 60 is the same as the 1500's. There is a vacuum switch in the transfer case that engages a sliding "coupler" that disengages the right side axle shaft. Shoot, my '91 dakota with ifs had a very similar system... had to change the vacuum switch ($35 iirc) and it looked like the same part used on my ram.
I am almost sure that when they changed the trucks (2500-3500) to AAM axles and the manual or electrically shifted transfer case- (New Process 273) they got rid of unlocking front hubs altogether - so no hubs to fail and no (axle disconnect ) just a transfer case front drive line engaged or disengaged mode.
