Ram1500 EcoDiesel V6 revealed!
   / Ram1500 EcoDiesel V6 revealed! #531
We have that on our '97 1500 4x4. Eventually things get stuck and it costs $400+ to have it fixed. Aaron Z
If they are turning all the time how do they get stuck? And a $400.00 repair on a 97 truck I don't think is too bad. I think it was $1,800.00 to fix the 4x4 hubs on my 02 f250 7.3. Plus it had to have ball joints at 110,000 and 230,000 miles
   / Ram1500 EcoDiesel V6 revealed! #532
On ours, there is a vacuum actuator in the front axle. Something internal started sticking and it would get stuck in or our of 4wd (vacuum lines were good).
Had it fixed and did the seals, bearings and the balljoints at the same time (total was over $1000 IIRC). Lamentably, the moron who did it didn't do the ujoints (he told me that "they should probably be done soon" when I picked it up) and one let go within 3 months, so we got to do the seals again (at another shop). Needless to say, the truck hasn't been back there since.
Aaron Z
   / Ram1500 EcoDiesel V6 revealed! #533
Yeah, it looks like crap. I'd take it off your hands for a small fee.
Nice looking truck, I'd love to find an old 12 valve in near mint condition, low miles, and priced cheap. They are pretty hard to find.
I'd say that if you just got 2 out of those 3 wishes, you'd be doing well !
Rgds, D.
   / Ram1500 EcoDiesel V6 revealed! #534
i am one. my trucks are a 94 and a 97. i have no fear of working on them and i can fix anything that is fixable on the side of the road, no pulling of cabs needed. i have always carried a toolbox with and will continue to do so. some people might think i'm crazy, but my tucks get better MPGs than the current offerings, are paid for, and are simpler, sure little things break but hey it's 17 or 20 year old truck and still cheaper than a new one.
You are speaking of ease of maintenance and I agree that some of the newer stuff is more difficult to get to some parts that need replaced. One nice thing about new is my $15 scan obd2 tool will tell me exactly what the problem is 90% of the time.
My point about reliability was on comparing the actual number of breakdowns. I have noticed less problems from my new vehicles verse 20 years ago when they too were new.
   / Ram1500 EcoDiesel V6 revealed! #535
On ours, there is a vacuum actuator in the front axle. Something internal started sticking and it would get stuck in or our of 4wd (vacuum lines were good). Had it fixed and did the seals, bearings and the balljoints at the same time (total was over $1000 IIRC). Lamentably, the moron who did it didn't do the ujoints (he told me that "they should probably be done soon" when I picked it up) and one let go within 3 months, so we got to do the seals again (at another shop). Needless to say, the truck hasn't been back there since. Aaron Z
The 1/2 ton and the 3/4 and up are different systems on the rams. The 3/4 up do not have vacuum lines to the hubs. And if you have a manual shifter for the transfer case there are no vacuum lines at all for the 4wd system.
   / Ram1500 EcoDiesel V6 revealed! #536
This has a lever on the floor to shift the transfer case and vacuum line to the middle of the axle (more or less) which (as I understand it) moves something inside the axle (in the diff itself?) to engage the 4wd, but it does not have hubs that unlock, so the ujoints at the wheels are always spinning.
Edit: Pictures of the guts of the system and a better description can be found at: Diagnosing 4WD Engagement Problems on Dodge Ram pickups
Aaron Z
   / Ram1500 EcoDiesel V6 revealed! #537
This has a lever on the floor to shift the transfer case and vacuum line to the middle of the axle (more or less) which (as I understand it) moves something inside the axle (in the diff itself?) to engage the 4wd, but it does not have hubs that unlock, so the ujoints at the wheels are always spinning. Edit: Pictures of the guts of the system and a better description can be found at: Diagnosing 4WD Engagement Problems on Dodge Ram pickups Aaron Z
I'm pretty sure that is only on the half tons. I will check my 2013 power wagon tomorrow and verify. And at $1000 you still got off way cheaper than I did with my 02 f250. And all they did was hub repairs on the ford not u joints or anything else at that time.
   / Ram1500 EcoDiesel V6 revealed! #538
Not sure about the newer ones, but my '96 2500 with dana 60 is the same as the 1500's. There is a vacuum switch in the transfer case that engages a sliding "coupler" that disengages the right side axle shaft. Shoot, my '91 dakota with ifs had a very similar system... had to change the vacuum switch ($35 iirc) and it looked like the same part used on my ram.
   / Ram1500 EcoDiesel V6 revealed! #539
I think that it was closer to $2000 than $1000, but it would have been a decent deal if he had bothered to call me and say "these ujoints look iffy, should I replace them while I am in here?" I would have said yes in a heartbeat.
As it was we spent a fair amount at another shop (not sure how much, my FIL got the bill) to redo the same work within 3-4 months when one of the ujoints fell apart.
Aaron Z
   / Ram1500 EcoDiesel V6 revealed! #540
I think that it was closer to $2000 than $1000, but it would have been a decent deal if he had bothered to call me and say "these ujoints look iffy, should I replace them while I am in here?" I would have said yes in a heartbeat. As it was we spent a fair amount at another shop (not sure how much, my FIL got the bill) to redo the same work within 3-4 months when one of the ujoints fell apart. Aaron Z
Don't see how you can blame the truck for faulty work done. The whole point of this is someone said yeah I'd buy the ford for the manual hubs alone. I'm saying I've had 3 fords much newer than your ram have problems with the 4wd hubs. An 02 and 2 08's so to me the ford hubs/ 4wd system is inferior. Before all the ford groupies get bent out of shape let me say again to me the ford hubs are inferior ymmv.
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
Fire Truck (A51692)
Fire Truck (A51692)
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
