Humidification in winter
   / Humidification in winter #31
We just built a new house,using open loop geothermal heat/ac. So far this winter the humidity has stayed around 35-40%. Do you all think we need to add humidifier?
It depends -- are you comfortable? I can tell when it's time to switch on the humidifier for the season when I start getting sinus issues. We have ours set to 45% (its highest setting) and it really helps. When outside temperatures drop during an extreme cold snap, I will crank it back to 30-35% if I start seeing too much moisture/frost on the windows.
We mainly heat with geothermal system, but supplement with wood fireplace (also for enjoyment). The fireplace will definitely dry out the interior air.
   / Humidification in winter #32
This chart might help.
   / Humidification in winter #33
I have an old Aprilaire furnace humidifier. The instructions say not to use softened water and indeed, I can see where the original owner re-plumbed it from softened to unsoftened water. It does build up mineral deposits over time and needs the pad changed yearly and the deposits melted off with a mild acid every few years. I augment it with a Holmes portable humidifier in the bedroom.
   / Humidification in winter #34
I'm using the Aprilair 600. I use softened hot water for the humidifier. It stayed pretty clean until I forgot to add salt. Only took about three weeks to waste the water panel. Turned a healthy orange pretty quick. I'll stick to softened water. I replace mine at least once a year. The panel is about 10 dollars on Amazon.
377789 (A51573)
377789 (A51573)
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
1985 Miller Wildcat 350-D Welder (A55851)
1985 Miller...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2006 Isuzu NPR-HD Landscape Dump Truck (A55788)
2006 Isuzu NPR-HD...
NEW HOLLAND TS6.120 TRACTOR (A51406)
NEW HOLLAND...
