hi from Norway looking at zetor 7245 for snow blowing
   / hi from Norway looking at zetor 7245 for snow blowing #1
klb0208
london
zetor
hi there
we've just moved in to a new house at the top of a mountain ~ we need to.move snow and quickly
we've found a 1985 zetor 7245 with 2500 hours on. there is a plough with it but no snow blower or chains.
im looking for some real good advice on whether this will be up to the job and if so would we need to budget for chains and snow blower...
please help!
   / hi from Norway looking at zetor 7245 for snow blowing #2
Welcome from Wisconsin there are people here that will help you.
   / hi from Norway looking at zetor 7245 for snow blowing #3
Welcome to TBN!
From TractorData.com:
TractorData.com Zetor 7245 tractor transmission information
Gears: 10 forward and 2 reverse
As long as your snow blower works in forward gear, and your forward gears allow you to move slowly enough, then I would guess you will be fine.
You live at the top of a mountain in London? Really?
   / hi from Norway looking at zetor 7245 for snow blowing #4
That is a nice tractor. With the plow, that should be fine. Google says 70hp. A snow blower is nice, easy - but you probably don't need it. Get tire chains for the rear. Can you plug the tractor in to keep it warm for cold starting in the winter- makes things so much easier. Good luck and have fun.
Put the tractor undercover so you don't have to brush snow off the seat!
Thank you so much for your help - Karen
   / hi from Norway looking at zetor 7245 for snow blowing #6
Welcome to TractorByNet!
I moved your thread to the Zetor, Century, & Branson forum. :)
   / hi from Norway looking at zetor 7245 for snow blowing #7
:welcome:
   / hi from Norway looking at zetor 7245 for snow blowing #8
Welcome to TBN from Iowa. It all depends. If you get a lot of snow and wind snow blower would be advisable. Otherwise plough would be fine. The plough makes banks on the side of the road and when wind blows it will fill the plowed area with new snow. Over time the banks gets to high making the plowing and snow disposal difficult.
2015 MACK CHU613 TRI-AXLE (A50854)
2015 MACK CHU613...
2023 New Holland C332 Two Speed Compact Track Loader Skid Steer (A49461)
2023 New Holland...
3in Poly Pipe (A49461)
Unused 2025 CFG MX20R Mini Excavator (A49461)
Unused 2025 CFG...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
