Have 500 gal propane tank and want to add a second one?
/ Have 500 gal propane tank and want to add a second one? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I own my 500 gal propane tank and have been thinking for some time to add either a second tank or get rid of the 500 and buy a 1000.
A problem I have is that the tank I have is a on a slight grade and changing to a 1000 gallon tank would likely mean I would have to dig up the line to the house and that's something I don't want to do. The propane company--a farm supplier--said I could instead just put in a second 500 gallon tank and plumb the two together. This would accomplish the same thing. One problem there is the second tank would be in a line in front of the first and maybe six inches higher in grade. I think it would look OK.
I think I want to add the second 500 gallon tank but I know nothing about propane. Does this sound like a good idea and can anyone offer any commentary? My goal is to buy enough propane in ay when the price is low and I figure I can get a quick payback on the tank. Any advice appreciated.
/ Have 500 gal propane tank and want to add a second one? #2
Good Evenin Sixdogs,
I have a 330 gal about 40 ft out behind the house, that being said I wish I had a 500 !
My Vt house is small, and I pretty get through the winter with that tank. This has been a bad winter so I will probably have to get another 100 gals in March. We are planning an addition in the spring 18 by 28 ft and a bedroom above, so at some time I will upgrade to 500.
What I usually do is buy in August when the price is down, I maybe save a few dollars doing this. IMO two 500 gallon tanks wont be any more unsitely than a 1000 gal tank... By having a large capacity tank like that gives you some flexibility when it comes to ordering !
BTW I own the tank so i can shop various suppliers for best price. I dont know how quick a payback your looking for but the tanks are not cheap, but by owning your own and the ability to shop for price will be a big help ! ;):)
/ Have 500 gal propane tank and want to add a second one? #3
I have a 1000 gallon tank that I own and a leased 500 gallon. I only buy propane one time per year ( one trip for supplier ) and pay tank owners price to fill both. Always empty leased tank first in case you want to change supplier. No problem with grade or height as it is just vapor. My 1000 sits several inches higher than 500 leased tank. I fill up every year late July when prices are lowest.
/ Have 500 gal propane tank and want to add a second one? #4
Sixdogs,
I guess I'm a little stumped as to why you would have to dig up your line. I would move the 500 out { and sell it to me lol }, and put the 1000 in.
I removed my 330 that was rented and put in my 500 (I own). I always put blocks under the tank to keep the bottom from rusting.
/ Have 500 gal propane tank and want to add a second one? #5
Anything related to propane I let the pros handle. Last thing you want is a propane leak ... BOOM! :bomb:
/ Have 500 gal propane tank and want to add a second one? #6
I used to have two 120 gal tanks that were connected by a 1/4" copper line. worked fine. The gauges on the two tanks never agreed, you would think they would balance, but that didn't seem to matter. To add another tank, I don't see any need to disturb what is already in place.
There have been some changes in code for flexible gas line, I think I read somewhere. I suppose a gas company could insist that you bring everything to code while making upgrades?
I agree on the have the pros do it. It's not that unusual to have houses blow up from gas leaks. A gas explosion last year in Maine took out an entire section of a condo complex. :eek: Of course, that may have been professional work. :laughing:
/ Have 500 gal propane tank and want to add a second one? #7
Mine is underground. Nobody knows how big it is. If I needed more capacity, I would add an additional underground tank. Annual fills and an owned tank make for great pricing leverage.
/ Have 500 gal propane tank and want to add a second one? #8
If you instal a second tank, I'd plumb them so that you can use them separately. In case one springs a leak, or needs service, you could use the other. I'd cry if I lost 1000 gallons due to a leak.
/ Have 500 gal propane tank and want to add a second one? #9
To you guys that own your tank, (me too) have you had issues with propane companys wanting to charge you a "safety inspection fee" before they would fill your tank???
One company under 2 miles from me wanted to charge me a $50 inspection fee before they would fill since I owned the tank. The place I get mine from, I asked the driver ( who happened to be there tank installer filling in for the regular driver ) how mine looked. He checked it out and said everything is good!
Just wondering if any of you have had issues?
Sixdogs,
I don't want to dig my line up. That's why I am going to add a second 500 gallon tank. If I were to put in one 1000 gal tank I WOULD have to dig up the line because the tank would be slightly relocated. By adding a second tank I would need to scrape about four inches off the ground to add gravel and this second tank would be slightly higher than the first. I think it would look OK.
Pricing leverage is my point. I own the first 500 tank and would also own the second. That way I could fill up in June when propane is abundant. In farm country here, prices skyrocket in October because it is used to dry grain. Propane is the only way.
That's my thinking with the two tanks.
/ Have 500 gal propane tank and want to add a second one? #11
The way mine were plumbed, they had separate shut-off valves. You could use one or the other alone.
/ Have 500 gal propane tank and want to add a second one? #13
Putting of 1000 gallon Propane tank will be one-time process and will be safer to you rather than adding one more tank of 500 gallons with your previous tank. There might be sometimes leakage in the attachment which may endanger your life. Go for a good quality big tank .
kristinalva---Well, this is an old thread and I went with two 500 gallon tanks. When, or if I move and can take the second one with me. Plus, around here you still sell the one with the house that you own. As I may or may not have mentioned, the 1,000 gallon tank didn't exactly fit and would have required a lot of extra effort.
To me it seems it's equally as "safe" or safer in that one tank is always off and the tanks are 100 ft from the house. More on the plus side, I just filled up for the winter at $1.09 so my payback has been faster than anticipated. One large or two small; either way the ability to tie a larger purchase to seasonal price swings has paid off.
Any pics of your 2014 Eicher tractor? I don't think I have ever seen one.
Let me also add that I put the tanks side by side. I couldn't put it behind, and it was difficult in front so the only choice was side by side and it works OK. I put a new regulator in at the time and replaced anything I could. Plus I put some cedar trees in front of the tanks and in another year or two you won't know they are there.
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
2006 Club Car Carryall 2 Electric Utility Cart (A59228)
2006 Club Car...
2017 Scag Cheetah 61in Zero Turn Commercial Mower (A59228)
2017 Scag Cheetah...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
