diesel lover
- Joined
- Dec 21, 2013
- Messages
- 643
- Location
- whites town indiana
- Tractor
- Ferg. To 20, 1956 Massey F. MF 25 diesel, Ferg. 40, 1944 John D. A, 1965 cockshutt 40,
a radiator was recently changed on this vehicle. I cannot find any leaks or see how low the coolant is but there is no coolant available in the recovery tank of the car. I found no leaks but there could be a leak of course.Many of the new coolants are labeled safe for all makes and models. The real question is why is it low? Chris
I wish I knew. It is not wise to mix coolants if you don't know what's in there. There radiator is sealed so I can't tell what was put back into the systems.Who changed the radiator? Do they happen to remember if it was orange or green?
I drive a Toyota(different model) and a lot of other Toyota owners suggest only using the coolant available at the dealer. That is what I have done in the past ...
At my last job we used fleet gaurd universal coolant and it actually would work good with all makes all models. Many good factors about that coolant. Before mixing any coolant a very thorough flush is needed.Guys I know say to use only Toyota coolant. $24 or so a gallon for pre-mix and you should know if you have red or green/yellow and get the same kind. While I was buying some at the dealer recently, there was a fellow there getting a new radiator and water pump. He said he used a different coolant for the last change and his troubles started after that. You would think there would be an aftermarket coolant that works but there must be something more to it. I'm staying with Toyota coolant unless someone can convince me otherwise.
