flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,572
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Yes, there is. Whenever possible you should attach the work directly to the part being welded. You are relying upon the surface to surface contact of whatever you are welding to provide a current path. That at best is unreliable. Not to say it can't be done in a reliable fashion if due care and diligence is taken, along with routine maintenance/sanding of the top, but surface rust, paint, other forms of corrosion may exist either on the table or the "weldment".
I don't see the problem. His table is permanently attached to his welder ground. If you want a direct connection to the work piece, run a properly sized jumper cable between the table and the work piece.
