Repaired 8N stalling when trying to open up the throttle (yes, me again)
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #41
that's why you check spark before doing anything else ;)
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #42
Seems like too much air or not enough fuel is reaching cylinders. If not a vacuum leak then it might be the other. A fuel restriction/ Is fuel valve open all the way? Is there a filter on 8n's? Blow rust out the line. Is there water in the gas?
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #43
there are 3 stock 'filters' on an 8n fuel system.
helps if you are familiar with the machine in question when you give advice.
there is a sediment bulb as well.. adn yeah.. that traps water. whih is less common these days with ethanol in gas...
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #44
Yes Sir Captain! Err, wait, that's total b.s. There's a lot of people here who are familiar with their machines who give terrible advice. An engine that cuts out at higher rpms isn't exclusive to 8N's.
Being the expert you are, why not have him check the simple and least expensive things before sending him on the expensive road of a carburetor rebuild or replace? Even you state he has a fuel problem?
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #45
if you've bothered to read the entire thread.. you can already see what has been mentioned.
PS. if you think a carb rebuild is expensive.. you are doing something wrong.
basic kits are well under 20$
intividual parts, which can be had from many dealers, are even less. you can cut your own gaskets if you know the gasket paper thickness.
thus. a rebuild can be done virtually FREE if your seats and shaft packings are good.. IE.. just breaking down to clean .. all you need is a gasket set.
a sheet of g-paper can make 5 small ms carbs.. or 4 big ones.
Sure there are people that give advice on machines they know nothing about. I wish they didn't.
confuses the issue when someone walks up and yels out a guess.. then has to ask how the fuel system is even set up. :)
kinda casts doubt on the guess. ;)
the probably cause of the problem, I believe, has been covered to death here... already. :)
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
