Air compressor quick coupler that doesn't leak
   / Air compressor quick coupler that doesn't leak #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
Several of the cheap quick couplers on my air compressor hoses and air tools leak. Is there a brand or type that seals better than the rest? Is there a trick to making them seal?
   / Air compressor quick coupler that doesn't leak #2
i can't rember the typ of chuck i use but it doesn't leak like the old ones with the short nipple , the ones i use has a long nipple .
   / Air compressor quick coupler that doesn't leak #4
Hard to go wrong with Milton, at least in the past, since all mine are at least several years old.
   / Air compressor quick coupler that doesn't leak #5
If at one time they did not leak but now they do then try cleaning them up and put a little lite oil on them. That works for the one I have. They are all older.
   / Air compressor quick coupler that doesn't leak #6
I've got some USA couplers from the 1950's (from my dad, I'm not quite that old) that don't leak. A little silicone on the seals does wonders. Some new ones, Harbor Freight grade, do leak. Hmmmm. You gets what youse pays for (sometimes)
   / Air compressor quick coupler that doesn't leak #7
   / Air compressor quick coupler that doesn't leak #8
I have both HF and Walmart (Campbell Hausfeld)quick couplers and none of them leak and they mix/match very well. I guess I am just lucky to have not picked up any with a defective seal.
Thanks everyone. I think I'll try: cleaning, oiling, Milton, in that order, until they quit leaking.
   / Air compressor quick coupler that doesn't leak #10
If you do any spray painting stay away from oil and silicone. sometimes two male fittings the same style, one will leak & one will not, maybe thats where cleaning comes in.
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
Loftness Mulching Head (A51573)
Loftness Mulching...
2025 New/Unused Wolverine Point Quick Hitch (A51573)
2025 New/Unused...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
