Carts or Wagons to Pull Behind Tractor
   / Carts or Wagons to Pull Behind Tractor #1
tarzane
Member
Leander, Texas
John Deere 1025r
Seeking advice on best cart/wagon to get to pull behind my 1025R JD, to haul bulk materials, dirt, firewood, brush, etc. Brand, size, feature recommendations are sought. Thanks.
   / Carts or Wagons to Pull Behind Tractor #2
I've found that a carry-all works as good for me as a tow-able cart for the materials you mentioned...they are very adaptable for different hauling applications...
...a self dumping trailer is another story...
Thanks, /Pine! Is carry-all a brand name, or could you tell me where you got yours so I can look at their products?
   / Carts or Wagons to Pull Behind Tractor #5
Another selection:
3 Point Carry All For Tractors
A thing to watch for: some have the rear horizontal bars connected near the end. Those work for building a platform on, but you can't use a pallet or use it like forks.
A trailer is better for long items like logs or tall brush. With a carryall you have to carry it crossways or drag one end.
Bruce
   / Carts or Wagons to Pull Behind Tractor #6
One advantage of a carry-all, if you haven't thought about it, is you can make the platform to do just exactly what you want it to do, and it will sure "back up" a heck of a lot easier than any trailer.:) And will turn a lot sharper too! Not to mention it will probably be cheaper to buy/construct too.
thanks for the excellent information. It is very helpful.
Thanks, James KOUA, good points I'll take to heart.
   / Carts or Wagons to Pull Behind Tractor #10
Much depends on your terrain. If steep hills are involved, a carryall is safer than a trailer, and a trailer is safer than a wagon. As alluded in an earlier post, that same order applies for maneuverability. And reverse order for capacity- generally speaking, wagons have the largest capacity and carryall the smallest.
John Deere 333E (A47477)
John Deere 333E...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
(2) TRACTOR TIRES (A54757)
(2) TRACTOR TIRES...
2015 KUBOTA RTV 1140CPX (A51406)
2015 KUBOTA RTV...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
