Changing oil and filter...do you go by the vehicle oil monitor or months & miles?
   / Changing oil and filter...do you go by the vehicle oil monitor or months & miles? #41
Re: Changing oil and filter...do you go by the vehicle oil monitor or months & miles?
The amount of fuel the engine processes isn't relevant at all to me. What's relevant to me, is how well the oil is holding up, wear metals, etc.
Quantity of fuel processed, is the single most relevant measureable on a modern engine. With no other data, it's much more telling than miles, or hours.
Would you please elaborate on your post? Unless I am interpreting it wrong, you are saying that fuel consumption for either mileage or operating hours reveal more than any other factor? The issue I have with that statement is that for a person operating an engine with no trip computer or monitor to check exact fuel consumption, they have no really accurate way to measure the fuel used. I don't understand how your reasoning applies.
   / Changing oil and filter...do you go by the vehicle oil monitor or months & miles? #43
It doesn't tell you squat about the oil quality/contamination which, is my only concern... UOA is the proven method of checking the quality of,or how contaminated the oil in the engine is Not OLM, which is only a guess at best
   / Changing oil and filter...do you go by the vehicle oil monitor or months & miles? #44
Vehicles i do when convenient between 5-10'000k .....tractors around 300hrs
   / Changing oil and filter...do you go by the vehicle oil monitor or months & miles? #45
Yes, any single measureable.
Miles alone, aren't even a ballpark measurement without other measurements.
5k miles of inner NY city driving at an average speed of 15 MPH is worlds away from 5K highway miles.
125 engine hours pulling a trailer on a highway is worlds away from 125 engine hours idling at inner city traffic lights.
Temperature alone is meaningless without time, duration frequency measurements.
The single most telling measureable is fuel processed ( consumed ). A modern ICE is after all, a fuel processing machine. Example:
A highway 60mph driven truck getting 17mpg with indicated oil change at 8,000 miles has processed 471 gallons of fuel
A start/stop city driven truck getting 12mpg will/should get an oil change 'minder at the same 471 gallons or 5,600 miles.
A truck towing a trailer, or running rich, burns more fuel and as everyone knows, needs more frequent oil changes.
   / Changing oil and filter...do you go by the vehicle oil monitor or months & miles? #46
Doesn't "tell you squat" if you won't listen. If you do UOA, you must keep good records. Check how much fuel you burned between change intervals that you already established in the past from your oil lab results. I think you'll be surprised.
   / Changing oil and filter...do you go by the vehicle oil monitor or months & miles? #47
The Wifes Mazda CX-9 gets changed on 5K intervals. Its easy to keep up with as I can simply look at the odometer and if its 25K, needs oil changed, if its 30K, needs oil changed...etc.. I do not use Synthetic oil, just plain old Valvoline 5W-20.
On one that gets no miles like your Yukon, I'd just change the filter and top it off.
Thank you for your detailed response...it explains your post well and is thought provoking. :thumbsup:
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
Portable Restroom (A54865)
Portable Restroom...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
UNUSED PABREAK DB220-84" HYD DOZER BLADE (A57193)
UNUSED PABREAK...
