Ford 4630 compression
   / Ford 4630 compression #1
MGriff
Or
blue ones
Hi everybody;just joined tonight after following forum for a year+. We have a Ford 4630 w/ non turbo 201" engine thats showing some age. Blow by and some oil use. Ran a compression check today with engine cold. #1 250 psi. #2 290 psi. #3 290 psi. Know it is a tough question but what psi does a "good" tight motor run. Just trying to decide if it is time for a rebuild or run it one more season. Thanks in advance.
   / Ford 4630 compression #2
Diesel, right?
450-500 psi would be healthy.
You should run the test with the engine hot. Cold doesn't tell the whole story. Also a blow by test is useful.
   / Ford 4630 compression #3
Hot or cold, that's a tired motor. A leakdown test or hot compression test isn't going to make you feel any better.
john-bud and RickB. Thanks for the answer. Hot didnt change it much. #1 270 psi. #2 290 psi. #3 290. You re right dont feel any better. Thanks again
   / Ford 4630 compression #5
True, but it may show that the valves are leaking or the head gasket is bad. But, it's probably just time to bite the bullet and do an in-frame overhaul.
I know these motors are prone to electrollis. We have always run the treatment in the cooling system but is there anyway to check that before we do the overhaul?
   / Ford 4630 compression #7
low compression and a pinholed block (or liner ) are seperate issues.
   / Ford 4630 compression #8
Leakdown test each cylinder with the radiator cap off. Look and listen for bubbles.
With the cylinders open, pressurize the coolant system and sniff look listen for anything getting into a cylinder.
If you can borescope the cylinders, a coolant leak will scrub it clean as a whistle.
   / Ford 4630 compression #9
a holed' cyl wall should make a few other symptoms.
steam from exhaust.
maybee pressurized cooling system.. etc..
Thanks for the help. john-bud we will do your tests before we tear it down. It would be nice if it were valves/head but everything points to rings/cylinders. Just wanted to cover all bases 1st. Thanks again
   / Ford 4630 compression #11
Odds are it will need a rebuild AND valves ... but it's good to know just how bad it is before you start.
john-bud; I dont have a real leakdown tester so I pumped in 80 psi w/ air compressure. Motor was hot, each piston on TDC on compression stroke tranny was in gear so motor couldn t turn. In 60 sec lost an average of 20 psi. Could hear air leaking into crankcase. On a tight motor what would be a good leakdown result?
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
Case Titan 3530 (A61307)
Case Titan 3530...
2022 John Deere 1025R (A53317)
2022 John Deere...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
