Ford 4630 compression
   / Ford 4630 compression #1
MGriff
Or
blue ones
Hi everybody;just joined tonight after following forum for a year+. We have a Ford 4630 w/ non turbo 201" engine thats showing some age. Blow by and some oil use. Ran a compression check today with engine cold. #1 250 psi. #2 290 psi. #3 290 psi. Know it is a tough question but what psi does a "good" tight motor run. Just trying to decide if it is time for a rebuild or run it one more season. Thanks in advance.
   / Ford 4630 compression #2
Diesel, right?
450-500 psi would be healthy.
You should run the test with the engine hot. Cold doesn't tell the whole story. Also a blow by test is useful.
   / Ford 4630 compression #3
Hot or cold, that's a tired motor. A leakdown test or hot compression test isn't going to make you feel any better.
john-bud and RickB. Thanks for the answer. Hot didnt change it much. #1 270 psi. #2 290 psi. #3 290. You re right dont feel any better. Thanks again
   / Ford 4630 compression #5
True, but it may show that the valves are leaking or the head gasket is bad. But, it's probably just time to bite the bullet and do an in-frame overhaul.
I know these motors are prone to electrollis. We have always run the treatment in the cooling system but is there anyway to check that before we do the overhaul?
   / Ford 4630 compression #7
low compression and a pinholed block (or liner ) are seperate issues.
   / Ford 4630 compression #8
Leakdown test each cylinder with the radiator cap off. Look and listen for bubbles.
With the cylinders open, pressurize the coolant system and sniff look listen for anything getting into a cylinder.
If you can borescope the cylinders, a coolant leak will scrub it clean as a whistle.
   / Ford 4630 compression #9
a holed' cyl wall should make a few other symptoms.
steam from exhaust.
maybee pressurized cooling system.. etc..
Thanks for the help. john-bud we will do your tests before we tear it down. It would be nice if it were valves/head but everything points to rings/cylinders. Just wanted to cover all bases 1st. Thanks again
   / Ford 4630 compression #11
Odds are it will need a rebuild AND valves ... but it's good to know just how bad it is before you start.
john-bud; I dont have a real leakdown tester so I pumped in 80 psi w/ air compressure. Motor was hot, each piston on TDC on compression stroke tranny was in gear so motor couldn t turn. In 60 sec lost an average of 20 psi. Could hear air leaking into crankcase. On a tight motor what would be a good leakdown result?
2016 KOMATSU D65PX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
2014 CATERPILLAR CB24B DOUBLE DRUM ROLLER (A60429)
2014 CATERPILLAR...
2438 (A60432)
2438 (A60432)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
KOBELCO SK170-9...
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
