Fixing used Rotary cutter blades
   / Fixing used Rotary cutter blades #1
BBerni
MF135 (1975)
Hi,
I own an old rotary cutters where the 4 blades are used. I want to load up the cutting hedge before sharpening but I not sure what rod type I should uses
Blades thickness == ½ in
Any suggestion?
Thanks a lot.
   / Fixing used Rotary cutter blades #2
Buy new blades! It's not worth the risk. The heat could damage the blades, and then they come apart.:eek: Just not worth it to me.
   / Fixing used Rotary cutter blades #3
What he said. If you've ever had one break or come loose, you'll not even consider welding on them.
   / Fixing used Rotary cutter blades #4
Yep. Like the others said replace them. Too easy to start a crack and have a piece get flung off at high speed. Could go through a car door, or the side of a house. Won't do your tires any good either.
   / Fixing used Rotary cutter blades #5
Definitely don't weld them.
Larger gouges/etc. can simply have the gouged edge sharpened, they will still cut just as well.
Past a certain point they need to be replaced. They are not that expensive and last a long time.
Got it!
Thanks
   / Fixing used Rotary cutter blades #7
Have to agree, don't weld them.
I run a couple batwings and large fixed deck mowers. as much NOT-FUN as it is to buy6 blades at a time.. it's better than welding one and have it fly out the side or back of the mower and thru a concrete wall and thru the occupant and thru another wall.. yada yada
I seen a blade shoot out go thru a 500$ tire and hit a tree in a field.. and that one wasn't welded. just freak acident!
   / Fixing used Rotary cutter blades #8
Hmm we have had a local welding shop build up the tips of our bushhog blades since 1969 and never had a problem . They add about 4"s where we have a longer wear period . The look like a one sided axle . It's cheaper for us to just have two sets of blades and have them retipped than buy new all the time . And we get long life out of the retipped blades on staying sharp . Not sure on the steel that's used but it stays sharper than new blades .
Sent from my iPhone 5 using TractorByNet
   / Fixing used Rotary cutter blades #9
i'm surprised they want the liability!
   / Fixing used Rotary cutter blades #10
Hmm we have had a local welding shop build up the tips of our bushhog blades since 1969 and never had a problem . They add about 4"s where we have a longer wear period . The look like a one sided axle . It's cheaper for us to just have two sets of blades and have them retipped than buy new all the time . And we get long life out of the retipped blades on staying sharp . Not sure on the steel that's used but it stays sharper than new blades . Sent from my iPhone 5 using TractorByNet
They weld a new piece on the ends? Does it wobble or shake?
Set of (4) 24ft. Free Standing Panels (A49339)
Set of (4) 24ft...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A45336)
2018 Skyjack...
International Fleet Star 2070A Truck (A47369)
International...
3012 (A49339)
3012 (A49339)
2008 TROXELL KILL TRAILER (A45046)
2008 TROXELL KILL...
New Wolverine Auger 12'' & 18'' Bits (A48289)
New Wolverine...
