Fixing used Rotary cutter blades
   / Fixing used Rotary cutter blades #11
It sounds like they are hardfaced or they're using a special steel. The welding shop is likely following a special heat treating procedure to repair the blades. If they aren't is scary!:shocked:Definitely not something you want to try on your own. A broken blade can not only go through a tire, it can go through you.
   / Fixing used Rotary cutter blades #13
Ya I don't know what they use or do .
But they have been doing it for as long as I can remember . I know my dad had been having them do it since the early 70's .
All do is take a set and tell them I need the blades built up and sharp and they do it .
Have never had a tip break and the hog cuts 3"-4" trees like butter .
And ya I wouldn't try it myself . But they know what there doing .
It's a third generation place . They have been in business a long time as a welding shop .
Sent from my iPhone 5 using TractorByNet
   / Fixing used Rotary cutter blades #14
That is probably the key. No offense to the OP, but if you are coming on a tractor forum to ask what kind of rod to use, chances are you don't know enough to attempt a diy repair on something as potentially dangerous as rc blades.
   / Fixing used Rotary cutter blades #15
The place where I buy my PTO shafts also repairs driveshafts by welding them and rebalancing. They do this on everything from dragsters to earthmovers. So welding a lawnmower blade seems reasonable for someone with experience.
   / Fixing used Rotary cutter blades #16
Different types of steel. A-36 to HY-80. There is more to welding than running beads. ;)
   / Fixing used Rotary cutter blades #17
Hmm we have had a local welding shop build up the tips of our bushhog blades since 1969 and never had a problem . They add about 4"s where we have a longer wear period . The look like a one sided axle . It's cheaper for us to just have two sets of blades and have them retipped than buy new all the time . And we get long life out of the retipped blades on staying sharp . Not sure on the steel that's used but it stays sharper than new blades .
Wouldn't the "stays sharp longer" suggest a harder steel which is not as malleable and more likely to shatter? I'm under the impression that a more moderate steel is better all around in applications like this. I expect Bush Hog, Woods, Landpride, etc. have knowledgeable engineers who have optimized the steel selection in their blades.
   / Fixing used Rotary cutter blades #18
Used to be a old machinst local that would weld blades together. He's been dead for 30 yrsd or more. I know he had a heat treat method he used but dont know what it was. He heated, welded, stuck in lime or sand to cool, and repeated. I dont know how hot he heated, what kind of rods he used, or anything like that. Never heard of any of his welded blades breaking. This is certainly not something I would attemp to do.
New Polaris Razor Roll Bar (A46502)
New Polaris Razor...
(5) Tractor Wheel Weights (A46502)
(5) Tractor Wheel...
2009 Peterbilt 384 T/A Day Cab Truck Tractor (A46683)
2009 Peterbilt 384...
66in. Skid Steer Bucket (A46502)
66in. Skid Steer...
3018 (A46502)
3018 (A46502)
76in. Skid Steer Skeleton Bucket High Side (A46502)
76in. Skid Steer...
