Ford 8N crankshaft pulley wiggle and a clicking noise arising up front
   / Ford 8N crankshaft pulley wiggle and a clicking noise arising up front
As suspected, the pulley is tightly bolted to the crankshaft and probably bent. Don't know if this is a new problem or if I just noticed it.
   / Ford 8N crankshaft pulley wiggle and a clicking noise arising up front #12
What happens when rpm are increased in terms of the clicking sound?
   / Ford 8N crankshaft pulley wiggle and a clicking noise arising up front #13
This noise wouldn't happen to be an exhaust manifold leak?
   / Ford 8N crankshaft pulley wiggle and a clicking noise arising up front #14
Seems I recall my buddy saying that a PO of his 9N didn't get the notch in the pulley aligned on the crankshaft key, before tightening, and it also had a bad wobble. Gave it some hammer therapy setting on a old piece of heavy shafting, and straightened it out, dressed with a file, and eliminated the wobble.
   / Ford 8N crankshaft pulley wiggle and a clicking noise arising up front #15
The ticking noise is one of two possible sources - First thing to check is valve lash. The other source is a liner that is loose and moving up and down with the piston. Obviously, the valve adjustment should be your first move. Loose liner can be verified by pulling the head. Don't run it too much longer before checking the valves. If it is a loose liner, it will eventually wind up in the oil pan.
The loose sheet metal pulley is fairly common. If memory serves, they were riveted to the crankshaft hub. The right way to fix that is replace it with a one piece machined pulley. I replaced mine during an overhaul so I couldn't say if you have to pull the axle for replacement. This needs to be addressed fairly soon because the pulley will eventually part ways with the hub and may ventilate the radiator - Best scenario is it will just overheat. If your luck is like mine, it will happen when you are at the farthest point from the barn.
   / Ford 8N crankshaft pulley wiggle and a clicking noise arising up front #16
It's not complicated to remove the front axle and radiator. But it is some work.
   / Ford 8N crankshaft pulley wiggle and a clicking noise arising up front #19
any news?
When the throttle is opened up, the clicking sound appears to become more faint or to disappear entirely.
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
3pt Hydraulic V Plow (A50120)
3pt Hydraulic V...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
FAKE (A52472)
FAKE (A52472)
