Diy compact tractor
   / Diy compact tractor
Lay shaft turned and slid into place
Just lots of bits just now, will hopefully come together over the next week or so
   / Diy compact tractor #14
Progress is progress. :D
How about the clutch?
   / Diy compact tractor #15
Following along. Very interesting.
Where are you located?
   / Diy compact tractor #16
Just a thought, keep your clutch, transmission, and the light duty parts at the highest rpm possible. Do your speed reduction with your heaviest components. If you notice in most tractors, the transmission is run at engine speed with heavy "Bull" gears carrying the high torque to the rear wheels.
Thanks for the advice, I had already given that some thought, the belts are running engine speed on good sized pulleys, thus keeping them at the lowest torque and highest speed. The only downfall is that my hydraulic pump will be clutched
Some work on narrowing the rear axle today:
Swict 78" Bucket (A57149)
Swict 78" Bucket...
14' Avalanche Snowbox (A55272)
14' Avalanche...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
TANK MANIFOLD (A55745)
2016 Komatsu PC360-11 Hydraulic Excavator, S/N A35687, PIN# KMTPC256CGWA35687, Turbo Diesel Engine, (A59076)
2016 Komatsu...
2018 Ford Fusion SE Hybrid Sedan (A56859)
2018 Ford Fusion...
