Missing 777
   / Missing 777 #261
This time line has a significant variation from the one you are referring to. According to CBS, the significant change in course happened 2 minutes after the sign off. The transponder stop transmitting after the pilot said "all right good night".
From takeoff to final satellite signal - a timeline of Malaysia Airlines Flight 370 - CBS News
Just add to the confusion. I read this morning the "new" flight coordinates were entered two minutes prior to the good night sign off but turn was initiated a short time there after.
So the fire theory only partially fits. Imo
   / Missing 777 #262
Had to do some more research to clarify what I thought I had heard. I guess it might be "sort of" flyable with a computer failure.
http://www.davi.ws/avionics/TheAvionicsHandbook_Cap_11.pdf
11.5.2 Mechanical Control
Spoiler panel 4 and 11 and the alternate stabilizer pitch trim system are controlled mechanically rather
than electrically.
question about 777 flight controls [Archive] - PPRuNe Forums
Part of post 1:
I was wondering if the 777 fbw controls allow for manual reversion.
Part of post 2:
The above modes still require electric power. When it is not available, the mechanical backup you refer to is used to control the plane.
It consists of cables from the flight deck to selected spoilers, and the stabilizer. As far as I know, there are no cables to the rudders.
Part of post 8:
The only control surfaces mechanically connected to the flight deck on a 777 are a pair of flight spoilers and the horizotal stab trim system.
Bruce
Yes, I read about 4 & 11. You can't fly that airplane with 4 & 11. Its the equivalent of putting your hand up into the air when riding a motorcycle, or dangling your hand in the water when gliding in a canoe.
   / Missing 777 #263
That's what I was reading as well. The turn happened after the "good night". Anyhow, the post you linked to is plausible and probably best explanation I've heard so far if there was no criminal intent by anyone. Good find. :thumbsup:
   / Missing 777 #264
Yep.
While the turn happened AFTER the 1:19AM "Good night", it was programmed into the Flight Management System BEFORE 1:07AM (the time of the last "Call Home" from the Flight Management System). If they were having an issue and decided at 1:07AM to change course, why didn't they say something on the radio before they signed off with the Malaysian ATC 12+ minutes later (at 1:19AM)?
See the CBS timeline (which I forgot to link in my previous post #256): http://www.cbsnews.com/news/from-ta...l-a-timeline-of-malaysia-airlines-flight-370/
Aaron Z
   / Missing 777 #265
I misunderstood the timeline earlier and mixed up the actual turn with when it was programmed into the system. As described in your link (starting at ~0:28), the change in course was programmed into the Flight Management System before 1:07AM, well before the 1:19AM signoff with the Malaysian ATC.
Aaron Z
   / Missing 777 #266
It may have just been a good habit to put other coordinates in as you go along in case something happens. I don't know. When I drive in South Bend at night, I always look for escape routes at stop lights, curbs I can jump, trees I can slip through, etc... in case of car jackings. (I know that's sad, but that's life in this hades-hole :laughing:). And I have heard and read that it was programmed into the computer ahead of time, but I was never clear how anyone knows the time it was programmed in. Was that transmitted to the airline before communications died?
   / Missing 777 #269
The cartoon pretty sums it up. I have never heard so many "experts" that don't even seem to know how to answer the questions supposedly in their field, let alone any questions that drifted out of their scope. Where do they get these people? Just grab mooks off of the street?
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2018 SKYJACK SJIII 3219 ELECTRIC SCISSOR LIFT (A52705)
2018 SKYJACK SJIII...
2015 Ford F550 Service Truck (A52377)
2015 Ford F550...
2008 Genie S-65 65ft Telescoping Boom Lift (A55787)
2008 Genie S-65...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
