brand new tractor ...need help
   / brand new tractor ...need help #21
   / brand new tractor ...need help #22
I think that's only Canadian models that get a dynamo. My US model B2920 had an alternator.
He bought his in Michigan ... said it was dynamo & not alternator. Bought it about 2.5 yrs ago
   / brand new tractor ...need help #23
IIRC my 4520 has a 70 amp alternator but I can let it sit for a couple of months and it will start up no problem. Might wan't to take the dealer up on his offer and change the battery out.
   / brand new tractor ...need help #24
Agree with others. Put a trickle charger on the battery and should start right up after.
   / brand new tractor ...need help #25
   / brand new tractor ...need help #26
we are all hoping he has juice in the pole barn. Sometimes that's not the case. That, then requires removing the battery and taking it somewhere else to maintain..
   / brand new tractor ...need help #27
Its a new tractor, Call the dealer
   / brand new tractor ...need help #28
I just had another thought. I once left the key turned partially on after refueling or something where I was checking the gauges. That drained my battery dead, but I was able to recover it.
   / brand new tractor ...need help #29
This cold winter we are having here in upstate NY (as well as the rest of the country), finally killed the factory battery on my 10 year old, JD 4120 (same tractor as yours, but with fuel pressure cranked down a bit). During those years, I never used a trickle charger, or any kind of charger and, with one exception, the tractor always started good in the winter. My tractor is stored in an unheated barn, but I almost always use a block heater, for at least 1/2 hour, prior to winter starts. With that block-heater on, for just 1/2 hour, in temps as cold as -10 F, the tractor starts as well as it does in mid-summer.
In my opinion, based on my own experience, a trickle charger or battery tender should not be needed on this series of JD tractors. A block-heater, however, is recommended for cold-weather starts. This device will reduce engine wear by bringing up the oil temperature, allowing it to reach bearings and other critical areas faster than a start using nothing, or just the preheat feature on the ignition switch. You definitely have a defect, or some type of problem, if your battery failed to start your tractor that soon. It is probably just a defective battery, but may be some type of voltage leak. Do you have a block heater?. If not, I would be more concerned with premature engine wear in the winter than I would of any electrical issue.
The time my tractor did not start good, was a premature starter failure when the tractor was about 3 years old. I replaced the factory installed, defective, Bosch starter, with an aftermarket "Powerstrike" (1/3 the cost of the Bosch at the dealer), and the tractor has started great ever since. When that factory starter failed, I may have had the "clicking" sound that you describe, but I doubt your newer tractor still uses that older, defective "Bosch".
   / brand new tractor ...need help #30
That battery needs to be replaced. It should have been charged on a tractor that new and easily sat 2 months without issue, unless you left something on. Take it out, take it to your local auto parts store... when it tests bad, take it to the dealership and have them replace it as they offered. A starting battery should not be deep discharged and it should not have self-discharged in that time period. Its capacity/lifespan IS now reduced. It would still probably work, but why not get it replaced?
A trickle charger is not a bad investment, but it's likely not capable of bringing that battery back to a reasonable charge level. For that you'll probably need something that puts out a few amps.
Sitting 2-3 months at a time without a charger should be no problem though.
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
CLUB CAR (A55758)
CLUB CAR (A55758)
2015 CHEVROLET SILVERADO 2500 (INOPERABLE) (A58214)
2015 CHEVROLET...
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
2008 Isuzu NPR-HD Landscape Dump Truck (A56858)
2008 Isuzu NPR-HD...
