Power Required to Pull a Two-Bottom Moldboard Plow
   / Power Required to Pull a Two-Bottom Moldboard Plow #1
AK47
Kingston, Ontario
Kubota L3300
Hello,
I just recently purchased a Kubota L3300 used tractor that is about 33 HP and has simple 2wd. I'd like to use it to plow about 2 acres of land to plant a few crops like corn and garlic. Before I go ahead and do that, I'd first like to find out if this tractor has the HP and weight to pull a 1 bottom plow let alone a 2 bottom plow on the first pass.
Anyone have any experience using these type of tractors for agriculture? Your input would be appreciated.
Thanks
   / Power Required to Pull a Two-Bottom Moldboard Plow #2
Welcome to TBN from northern Ontario.
I had a Farmall C (20 hp) that I used to pull a two bottom breaking plow with no problems.
   / Power Required to Pull a Two-Bottom Moldboard Plow #3
You've got plenty of HP. It's whether you can hook it to the ground or not. Not sure what your tractor weighs?? Also, are you talking about a 3pt mounted plow?? If so, it'll help with the traction problem versus a pull type.
According to TractorData.com - information on all makes and models of tractors your tractor weighs 2610-2765lbs. You should be fine with a 2 bottom plow. If you've added rear tire fluid or have wheel weights to boost that weight it will handle it even better.
   / Power Required to Pull a Two-Bottom Moldboard Plow #4
Our full size farm tractors required about 10- 12HP per 14" bottom when we were plowing. Now I pull a single bottom 12" with either a B8200(Ags) or BX2200(turfs) with no problems. I plow in 4WD and do not add any weight, other than keeping the loader on the BX, cause I'm too lazy to take it off. An L3300 should handle a 2-bottom with ease, and maybe a 3-bottom in good conditions.
Thanks for the quick responses and appreciate the welcoming. I also wanted to point out that the land I'm using is a very hard clay soil so I'm not sure if that will significantly impact the ability of the tractor to plow through that soil efficiently. I also have a loader on the front which worries me about the tractors ability to pull a two bottom plow due to traction issues.
   / Power Required to Pull a Two-Bottom Moldboard Plow #6
I would stay with a 2 bottom. It might take a little longer, but you wont have any problem.
   / Power Required to Pull a Two-Bottom Moldboard Plow #7
I pulled a 2-12 Ford 101 behind my Kubota B3300SU through rock free, sandy loam, with no particular problem but it had four wheel drive and R4 tires.
Pulling a moldboard plow is high draft force work.
I am doubtful you can pull a two bottom plow with two wheel drive, through clay.
I think you will need to restrict yourself to a single plow in clay. For two acres a single bottom plow is not that great a restriction. With a single plow you can go to 14" wide moldboard, which will be a limited compensation.
   / Power Required to Pull a Two-Bottom Moldboard Plow #8
Agreed. Knowing you have clay, you'll be happier with a 2-bottom. And the loader is a help, not a hindrance. It'll act as a fulcrum to aid traction. We added front end weights to our tractors when plowing, except for the loader tractor. It didn't need any. Watch your rear wheel slippage-you may need some wheel weights, or calcium in your rear tires. Or just put her in 4WD and give it a try!
   / Power Required to Pull a Two-Bottom Moldboard Plow #9
Are your rear tires loaded? If not I would get rim guard in them and then hook up to the 2 bottom and go.
   / Power Required to Pull a Two-Bottom Moldboard Plow #10
Hello,
OP's tractor has two-wheel drive.
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2020 JLG Telehandler (A49461)
2020 JLG...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
