Tarnold
Hooked up the new grapple to the LS 3038H, and got scared real quick. 60" grapple at 650 lbs was probably to big, tried to lift a wet log 8'x22" and rear end went up like a rocket. Loaded tires and a box blade on the rear. Knew the load was heavy but wanted to see what it could do. So found a concrete calculator and want to build a weight box, but how much weight do I need? Rear lift rated 1433 lbs. FEL rated 2088 lbs. I don't want to max anything, so what percent of capacity should I shoot for in ballast weight?
