Mahindra 3316 front axle oil level
   / Mahindra 3316 front axle oil level #1
seal oil
nfld canada
2010 mahindra 3316 shuttle tlb
I am confused about how to check the oil level . In my operators manual there is a picture of an oil level plug on the left front of the axle . I removed the plug and no oil came out . There are also oil level plugs located on the rear of both gear cases that I removed and oil did come out . Is the oil level plug in the front the one to check the oil level or the ones on gear cases ?
   / Mahindra 3316 front axle oil level #2
You want to check the oil level for the front axle in three places:
1: the plug facing front in the axle tube
2 & 3: each side near the front wheels there is a plug facing the rear top of the knuckle housings
So I guess the oil level plug facing the front is low on oil if no oil comes out there ?
   / Mahindra 3316 front axle oil level #5
Make sure to check the tightness of the bolts that hold your cases together. Mine had right side bolts come loose. Now I check them every time I check the loader mounting bolts and I added Loctite.
Thanks . I will check mine also .
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
1762 (A60430)
1762 (A60430)
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2016 Dodge Journey SUV (A59231)
2016 Dodge Journey...
