Anyone use Glycerin for tire ballast?
   / Anyone use Glycerin for tire ballast? #1
Surgeon
Vermont
MF 1428
   / Anyone use Glycerin for tire ballast? #2
Kind of pricey compared to other ballast options, but seems like a good idea from a strictly adding weight perspective.
   / Anyone use Glycerin for tire ballast? #3
Unless diluted to a watery consistency (what do you dilute it with) it would be too thick to move around the tire and that would cause tire balance issues. I don't know about the freeze properties of glycerin either + the cost would be prohibitive unless you could get it for free somewhere. Lots of better and cheaper options.
   / Anyone use Glycerin for tire ballast? #4
I know this is an old thread but I think using glycerin would have some major concerns. Glycerin is a petroleum product and the only thing that can dilute glycerin is itself a petroleum product and is quite flammable & explosive. Put in plain english - you can not dilute glycerin with water. Glycerin is diluted with any number of types of alcohol, types of kerosene and similar products. Not a mixture that you want in your tires.
Glycerin is a sugar alcohol. We use it medically all the time. It is considered non toxic and does dilute with water.
   / Anyone use Glycerin for tire ballast? #6
Where did you get this information? In plain English glycerin is very soluble in water and is not flammable or explosive. It is so very soluble in water it is considered to be hygroscopic and will suck water out of the air. Flash point of 433 deg. F. Ethylene glycol with a flash point of 232 deg. F. will burn quicker. 70% glycerin in water the freeze point is -36 deg. F. You can eat this stuff!
iDrive TDS-2010H...
2022 LEEBOY 8520B ASPHALT PAVER (A60429)
2022 LEEBOY 8520B...
2014 F-150 STX (A56438)
2014 F-150 STX...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
JOHN DEERE 6430 PREMIUM TRACTOR (A60430)
JOHN DEERE 6430...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
