Gannon Box Blade with hydraulic rippers
   / Gannon Box Blade with hydraulic rippers #11
Bryan would it be possible to get a quick sketch of all the dimensions you want.
Sounds like your looking to build one for him if he's interested
   / Gannon Box Blade with hydraulic rippers #12
Hey Brian,
would you mind sending me a brief sketch of the dimensions you want and i'll make sure to get them all. It sounds like your offering to build this cylinder if Murry918 is interested in buying.
Dave, actually the only other measurements that I need are the following.
At the top, the bar that goes between the clevis on the cylinder, how wide
is that bar?
At the bottom, the rod of the cylinder goes between a clevis, how wide is
the inside of that clevis?
Are both of the pins, (top & bottom) that hold the cylinder in place 3/4"
dia pins?
If you can get me that info, that would be great.
Thank you very much. :thumbsup:
   / Gannon Box Blade with hydraulic rippers #13
The rod just has 1.75 "round stock with a hole bored through it. Top needs to have enough clearance for 3/4" steel plus see the pictures
   / Gannon Box Blade with hydraulic rippers #14
Dave, thanks for all the info. :thumbsup: ;)
   / Gannon Box Blade with hydraulic rippers #16
I forgot to measure the diameter, I figure Murray918 can measure them on his box scrapper if he wants someone to make the cylinder not sure where he disappeared too.
Brian,
I just made a payment through PayPal for the cylinder and again, I'll get those measurements when I get home this evening.
Dave,
Thank you very much for all the measurements that you provided without your help I would have had to spend $500.00+ for a cylinder. I'm glad there are people out there like you that will still go out of the way to help another person out.
   / Gannon Box Blade with hydraulic rippers #19
Dave,
No problem. I think the pins are both the same just forgot to check. Sounds like a much better deal going through Brian. I know lots of people here have purchased cylinders from him when I come up with another $1300 for another valve and cylinder I'll be purchasing a side link from him
I'm very new to the tractor world. I'm not familiar with what a side link is
2008 Ford F-450 Service Truck (A53422)
2008 Ford F-450...
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
294 (A52706)
294 (A52706)
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
