Property fencing question....
   / Property fencing question.... #1
mdjohn1427
Member
Alabama
Mahindra 5010 HST Cab
My property (80+ acres) was surveyed before we closed the sell. I now want to fence part of my property. I have found the pins (corners). The south end of the property is 2600 ft. from pin "A" to pin "B". Lots of trees and a few raises between the pins. I can't see further than 150 feet. What's the easiest way to determine if I'm on my property. I have the corrected plat with all the longitude and latitudes. Can a digital compass help do the trick?
   / Property fencing question.... #2
Why didn't they put stakes in every 50'??
Hmmmm.... Didn't think of that when they were surveying the property. I'm now looking for a way I can accomplish this task without paying another $2000.00.
   / Property fencing question.... #4
That was a dirt cheap job. I paid 4k for doing a 16 acre plot marked every 75'.
   / Property fencing question.... #5
I would resurvey or give the other guy a few feet when in doubt. Also would depending on what kind of fence and how hard it is to move. Don't ask how I know
Scott
   / Property fencing question.... #6
Start by talking to the owner of the next door property perhaps he can assist you in getting a route of way opened up. Our next door neighbor allowed us to clear back a 20 foot R.O.W. of all the scrub brush and just leave the larger trees You can see over the ridges by building a raised platform to get above the rises and bushes so you can visually see the other end. Buy a cheap surveyor level that you can line up with the other corner pin position by placing it on the platform. Cut any trees that are in line with your property line by sighting thru the surveyor level and having someone mark each one to take out. Once trees/shrubs are out, using the level again, place pins as close as you need them to mark the exact property line as agreed with the neighboring property owner.
   / Property fencing question.... #7
Well, you need to clear a strip from pin to pin so you can have a clear line of sight. Otherwise your fence will tend to look like a dog's leg. Hopefully with a clear line of sight you can see pin to pin and lay in the fence line. If not you will have to learn and use survey techniques or have the lines you want to fence flagged. It should not be that expensive if the corners have been surveyed and pinned. However, it will be a lot easier and cheaper if the fence line is cleared. If you can see pin to pin then follow the advice given by Gary (#6). Except - its probably fairly certain that your property corner surveys are the most current and accurate between you and your neighbors. If you do the marking of the property line - follow the corner surveys. Your neighbors consensus may have no basis in fact and the surveyed corners are recorded fact.
   / Property fencing question.... #8
I surveyed for 43 years here in North Carolina. The easiest and quickest is to just hire the person that did the survey to come back and mark your PL for fence building. He has his notes and reference points to work off of. This will just be some labor charges since he will not be making a map.
   / Property fencing question.... #9
ditto that!
   / Property fencing question.... #10
X's 3. Probably be cheaper at this point than you think. No way I would build in 2' off the line, I wouldn't concede that much real estate.
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
