flywheel bolt installation on 1972 Ford 2000 tractor
   / flywheel bolt installation on 1972 Ford 2000 tractor #1
kennyl123
Pollock, LA
Ford 2000
Hi guys, I have installed flywheel to crank 3 times and 4 bolts go right in but can not get the other 2 to start. What am I doing wrong? Is there a way to tell how to line up bolts and holes?
   / flywheel bolt installation on 1972 Ford 2000 tractor #2
Usually the bolts are indexed slighty off from one another, it will only go on the crank one way. Its not much and you may not even see it but its a common thing.
   / flywheel bolt installation on 1972 Ford 2000 tractor #3
Ding Ding! Winner! You have 6 choices. One will work. When I remove a flywheel, I prick punch the O.D of the flywheel at the top where it sits. If I don't rotate the engine and use a 9/16 NF dowel in the top hole of the crank, the indexed flywheel goes on the supporting dowel correctly the first try.
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
