Can 4100/4110 FEL lift and curl at the same time?
   / Can 4100/4110 FEL lift and curl at the same time? #1
holzboat
Long Island, NY
JD 4110, JD X595, JD 4100
Just reading on an orange thread how the 1025R can't lift and curl at the same time but the 2320 can. Does anyone know if you can lift and curl simultaneously with a 4100 or 4110?
   / Can 4100/4110 FEL lift and curl at the same time? #2
I had a 4110 several years ago, and while i didn't have a FEL, I had the front hitch and blade and it would lift and angle at the same time.
I have a 4115 with the 410 FEL. I can lift and curl at the same time, but both become slower in speed when doing it. My 460 loader on my 4500 was the same way though.
   / Can 4100/4110 FEL lift and curl at the same time? #3
On most FEL controls you can feather the controls and do both raise(lift) and curl. If the raise is demanding full flow you probably will not be able to curl.
   / Can 4100/4110 FEL lift and curl at the same time? #4
This is correct, and it is in the loader manual for Deere loaders. At least it has been in mine so far.
   / Can 4100/4110 FEL lift and curl at the same time? #5
Yes, absolutely the 4100/4110 can do both, and there are many that say the 1023/5/6 can as well but the "sweet spot" is very hard to find.
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
40' CONTAINER (A51244)
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
TAKEUCHI TB235 EXCAVATOR (A51246)
TAKEUCHI TB235...
