Can 4100/4110 FEL lift and curl at the same time?
   / Can 4100/4110 FEL lift and curl at the same time? #1
holzboat
Long Island, NY
JD 4110, JD X595, JD 4100
Just reading on an orange thread how the 1025R can't lift and curl at the same time but the 2320 can. Does anyone know if you can lift and curl simultaneously with a 4100 or 4110?
   / Can 4100/4110 FEL lift and curl at the same time? #2
I had a 4110 several years ago, and while i didn't have a FEL, I had the front hitch and blade and it would lift and angle at the same time.
I have a 4115 with the 410 FEL. I can lift and curl at the same time, but both become slower in speed when doing it. My 460 loader on my 4500 was the same way though.
   / Can 4100/4110 FEL lift and curl at the same time? #3
On most FEL controls you can feather the controls and do both raise(lift) and curl. If the raise is demanding full flow you probably will not be able to curl.
   / Can 4100/4110 FEL lift and curl at the same time? #4
This is correct, and it is in the loader manual for Deere loaders. At least it has been in mine so far.
   / Can 4100/4110 FEL lift and curl at the same time? #5
Yes, absolutely the 4100/4110 can do both, and there are many that say the 1023/5/6 can as well but the "sweet spot" is very hard to find.
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
