Preserving/refinishing treated pine deck
   / Preserving/refinishing treated pine deck #1
Kopierguy
Member
Lake Conroe, TX
Ford 1710, Kubota L245, Kubota G1900
I have a 20 year old deck (treated pine) that has only been refinished one time using a deck stain. That was about 10 years ago and as I recall, that only lasted about a year. The deck is still solid and I am considering putting something on it to extend it's life. There is about 500 sq feet to be finished. I am considering pressure washing and allowing it to fully dry and then applying red off-road diesel. Does anyone have any suggestions as to the product I should use or the pros and cons of treating with diesel?
   / Preserving/refinishing treated pine deck #2
I'm going thru the same thing. So far, the best product I can find is oil based Deckscapes by Sherwin Williams. A guy I know swears it will last for 7-8 years if the prep is right. Right now, I am misting bleach / water solution onto it and letting it dry. It is starting to clean up some after 2 apps.
Pressure washing probably doesn't hurt but you have to wait a while before sealing.
   / Preserving/refinishing treated pine deck #3
I've never heard of using diesel to treat wood. I'd be somewhat concerned about tracking it onto the floors & carpet in the house. I have an all cedar house(Pan Abode) and cedar decks. I use Cabot Australian Timber Oil on both. Its be eleven years since last treated the house and decks. The house is doing fine - the decks could use another treatment. I noticed this winter that the water was soaking into the decks - normally it puddles and sheds off.
   / Preserving/refinishing treated pine deck #4
Olympic Rescue It. Has fine sand in it. Fills cracks larger than a toothpick the first coat. No splinters. Non slip. My front deck is 33 yrs old. Looks like it's good for another 33. It's the first pic. Second pic is rear deck, it's 15 yrs old. Comes in a wide variety of colors. Don't let price scare you. When you figure the coverage, it's worth every penny.
That finish looks good. Looks like it was just done. How long since you finished it and how did you apply it? Brush, roller or??
   / Preserving/refinishing treated pine deck #6
When I redo a deck for a client, I rent a large orbital sander from Home Depot and get a stack of sand paper. You can return what you don't use with the machine and get a refund on them. The sand paper is something like one foot by two feet in size. It's really easy to use and the results are amazing. After sanded, it will look better then when it was first built. Then I either use Sherwin Williams or Cabot products to stain and seal it. If there are nail heads sticking up, I remove them and install screws.
Eddie
   / Preserving/refinishing treated pine deck #7
X2 what Eddie says...good surface prep is the key to a lasting finish and I have always used Cabot brand stain with great results.
   / Preserving/refinishing treated pine deck #8
Two years, roller.
   / Preserving/refinishing treated pine deck #9
Eddie
What grit do you normally use, Eddie? Got any before and after pics?
   / Preserving/refinishing treated pine deck #10
It's been a couple of years since I did my last deck. I'm pretty sure it was a 36 grit paper that I did 90 percent of the sanding with, then finished it off with a 100 grit. I did two decks that year, one was on the lake and had a lot of things to work around and it was an odd shape. The other was a large deck of probably 500 sq ft. Both used quite a bit of sandpaper, but I bought a whole box for each job. If you are going to sand, you really want to have all the sandpaper you will need on hand and it's super easy to return what you don't need. I wouldn't think of sanding a deck without at least 25 sheets.
Sorry, no pics of sanded decks. I've only had a smart phone a couple of years and that's when I started taking pics of everything. I will say that with the boards being out in the sun for so many years, the wood was nice and dry and the sanding went pretty easy. The look is amazing and the change in how it felt to walk on it is like night and day. So many boards cup up at the edges and develop ridges that disappear when sanded.
I was going to refinish a small deck for a client a couple months ago, but after we got to talking, they have hired me to tear it out and build one three times bigger, and then add a second story deck above it. I'm starting that job on Monday :)
Eddie
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
John Deere 848G Grapple Skidder (A52384)
John Deere 848G...
1996 JCB 506B Telehandler (A53473)
1996 JCB 506B...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
