What does this spring go to?
   / What does this spring go to? #1
FELMOW2320
Rocky Face,Ga.
Kubota B2650
I was putting my mower deck on my B2320 hydrostatic tractor and found this spring hanging down.I looked on Messicks website and even went to the dealer and they couldn't find a picture of the spring.Any clue to where it hooks too?
   / What does this spring go to? #2
Looks like the bottom is broke. It probably fell from somewhere higher and just happened to get caught there.
   / What does this spring go to? #3
I'd look at the mower deck about where that spring is spatially located and see what it might hook to? I agree with ENC that it looks broke. Keep in mind this advice coming from someone that doesn't own a mowing deck. Someone knowledgeable will surely comment.
   / What does this spring go to? #4
In looking at the picture, look to the right of the spring and up. It looks to me like a piece of metal/bracket got sheared off or busted. The piece of metal that I'm looking at is painted gray. I'm thinking that is where the spring got connected to.
Good luck.
   / What does this spring go to? #5
There is also a broken looking edge by the yellow filter?
   / What does this spring go to? #6
I don't know, but it looks like there's another one similar at,,....
the top left of your picture.
   / What does this spring go to? #7
Johnson rod or Cannuter valve is my guess, but I'm no tractor mechanic ;)
   / What does this spring go to? #8
What is the purpose of the bracket that the spring is attached to. Does it move left to right in the photo. If so, it would make sense that the spring could have been attached to a bracket just to the right where it appears that something broke off that was just barely welded.
   / What does this spring go to? #9
Looking at the bottom of the bracket that the spring is on: It looks to me like that spring may go up. That bracket has scratch marks that look as thought the spring was attached to something above that bracket.:2cents:
What has quit working on your tractor?:D
   / What does this spring go to? #10
Remove the spring and examine the bracket. You will most likely find the wear on the bracket in the direction of the pull. My guess by the design of the bracket it went to the rear or to the tractors right. I would put money on rearward.
Gleaner R50 Combine (A50514)
Gleaner R50...
John Deere 825i Gator (A50514)
John Deere 825i...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
John Deere 455G Loader (A48837)
John Deere 455G...
