Questions about Grading Scraper Operation
   / Questions about Grading Scraper Operation #11
The offer stands Pappy.
Interesting on your plans. We're looking for a nice piece to build a metal barn/shop/home on right now.
   / Questions about Grading Scraper Operation #12
As it seems to be too often the case anymore, I agree with much of what has been said. We use a box scraper almost exclusively for trails and roads, but it has taken a lot of time, practice and patience. I use to often just drop my box scraper and hook up to our 10' drag scraper when doing long stretches of roads, but we now only use it occasionally on large areas. I am using a tractor with Top and Tilt along with a scraper with hydraulic scarifiers similar to jenkinsph which helps.
If I had the spare money and didn't hate swapping implements so much though, I would buy a LPGS to add to my inventory.
Larry, since "we" like to spend other peoples money so much,:thumbsup: maybe you should think about the Delta Hook quick hitch. Fits about any implement, you probably would not mind switching out implements so much then. I recommend this unit so that there are no issues fitting to implements that would otherwise need to be altered if a std type 3pt QH was to be used. ;)
   / Questions about Grading Scraper Operation #13
I'll be the first to admit that I'm a complete amateur with a box blade. I grew up on a wheat/cotton/milo farm and accumulated thousands of hours on a tractor running moldboards, chisels, disks, cultivators, etc., but never used a box blade. We didn't even have one.
So, I'm sure my lack of knowledge/experience/technique is amplifying the problem.
I think practice helps but as John mentions good rockshaft control is a must have. I also agree that you have to move slow enough to have time to react and make the needed adjustments. With your hst tranny you can slow down as John mention and feel the front dip or rise to make the adjustments. Sometimes you may have to stop then adjust and proceed.
   / Questions about Grading Scraper Operation #14
Brian, do you know a good marriage counselor...:laughing:
I've seen those and really like the concept, but my L5740HSTC is in the shop getting a third function added to go with my new grapple and before that I sprung for some new wheel weights and our M8540HDC needs...:licking:
   / Questions about Grading Scraper Operation #15
Sorry, no actually glad that I don't know of a good counselor. Haven't needed one so far. :thumbsup: As far as the Delta Hook, all I can do is :drool:.
Maybe someday. ;)
   / Questions about Grading Scraper Operation #16
Maybe someday. ;)
Man, it sure is cool though. Lemme see...3.5k for a rebuilt final drive...3.5k for a 4n1...7k for a brush cutter....and never got around to the tnt. Maybe next week! :laughing:
   / Questions about Grading Scraper Operation #17
I would not recommend unhooking the top link from the lpgs. You need to control the pitch of the tool closely and I also use the hydraulic top link for this.
Tongue-pulled scrapers behind an ATV or truck seem to do OK.
RDrancher said:
I think that most folks just plain go to fast with their box blades.
There are several Youtube videos of people pulling driveway graders so fast they bounce over the road.
This one, at about 35 seconds, lost most of the gravel while spending too much time in the air.
Homemade Drag grader - YouTube
In my opinion, about half the speeds in this video are too fast to let the tool work right---especially the Jeep at 17 seconds.
Gravel Rascal - ATV Driveway Grader & Landscape Rake - YouTube
There are others, but these are the first two I found.
Bruce
   / Questions about Grading Scraper Operation #18
Bruce
Yes but pull type and three point are different animals. If you unhook the top link from a 3ph land plane it will pitch forward too much and most likely skip and bounce along behind the tractor.
   / Questions about Grading Scraper Operation #19
Of course, it's caused by the pivoting of the box blade up and down in the opposite direction of the front of the tractor. With the box blade, every pass exacerbates the problem.
I see people mention this a lot, but I have never run into this problem. I do all grading and road maintenance with my 3-pt all the way down, so that the box is floating on the road surface all the time. It would take a serious dip to get the box to lift off the ground, as it would require the rear of the tractor to pivot up beyond the down-limit of the 3-pt arms.
I suspect when people run into this problem, they are grading with the box slightly elevated. I rarely need to do that, maybe only when distributing fresh material.
   / Questions about Grading Scraper Operation #20
s219, 3-pt all the way down...how does that stop the box blade from continuing to dig deeper & deeper; rather than just grading? At least for me, that's what always happens unless I am working the T-N-T constantly? I am always eager to learn better techniques. thanks, Greg
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A48082)
2017 Bayliner VR5...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
Guard Rail Pieces (A48081)
Guard Rail Pieces...
