94Bullitt's Attachment Restoration Thread
   / 94Bullitt's Attachment Restoration Thread #1
94BULLITT
Super Member
USA
yes
I made this thread to show that you can take something that does not look that good and make it look like new. I also have a couple of broken attachments that I repaired.
The first is a Woods RB60 Blade. I showed pictures of this one in another thread.
These are the only before pictures I have of it.
To clean it up I used a wire wheel on an angle grinder and paint stripper.
After:
Here is my Version 1 imatch.
I used sand paper to remove rust and feather out the scratches.
After: (it already has a battle scar from use)
Version 2 imatch. It was just green and needed to be Orange.
I just scuffed the paint with a scotchbright pad.
After:
Woods LR72 Rake
It was really bad looking a couple years ago, I repainted it Woods burnt orange. I just scuffed the frame work and shot it orange. For the bolts I used galvanized paint, IDK how it will hold up. I brushed the tines gray.
After:
Disk for garden tractor:
I forgot to get a picture of the whole thing before I started.
I had too much weight on it and broke it with the Cub Cadet 2206. I had to straighten and weld the tongue. Straighten one of the axles and build new wood blocks (is it called boxing) for the axles to run in. I cleaned everything thing up with a wire wheel. I am going to get rid of this disk since I have no use for it.
After:
   / 94Bullitt's Attachment Restoration Thread #2
Re: 94 Bullitt's Attachment Restoration Thread
Nice work :)
What brand of paint did you use? How was it applied?
   / 94Bullitt's Attachment Restoration Thread #3
Nice work. :thumbsup:
   / 94Bullitt's Attachment Restoration Thread #4
hey man. I need to borrow the rake. can I borrow it for one day
   / 94Bullitt's Attachment Restoration Thread #5
Are you sandblasting? How are you prepping for paint?
Nice work :)
Thanks. Everything but the disk was sprayed. The disk was brushed, the but the disk blades were sprayed. I used genuine Kubota paint, the only thing I can find that matches the tractors. The disk, rake tines, and cutting edge on the blade I used rustoleum paint. The blade I used a Devilbis Finsihline to paint it and everything else that was sprayed I used $8 Harbor freight HVLP gun. I like the size of the harbor freight gun for tractor implements and I don't have to clean it up real good.
Thanks
Let me know when and I will email it to you.
Wire wheel on a angle grinder and sand paper.
   / 94Bullitt's Attachment Restoration Thread #8
you read my mind brother
   / 94Bullitt's Attachment Restoration Thread #10
I think this thread should be titled "How to paint EVERYTHING orange". Just kiddin
Very nice looking stuff.
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
KOMATSU D65WX-18 CRAWLER DOZER (A60429)
KOMATSU D65WX-18...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
