Do they make this type of snowblower?
   / Do they make this type of snowblower? #11
wow, i cant even imagine spending 11k to put a snowblower on something, much less a compact tractor. more power to you; but thats insane!
naa, didnt even think twice about it. was going to spend at least 6k in a well built rear unit. but after 14 years of driving backwards my neck said enough.
we get lots of snow in north idaho. its been worth every penny i spent. id do it again in a heartbeat.
mind you, i sold my old tractor for $10,500 so the blower only cost me about $500
   / Do they make this type of snowblower? #12
How does that setup work? I know the PTO drives a pump but how do you turn th blower off, disengage PTO?
   / Do they make this type of snowblower? #13
the pto controls everything. it also has 4 built in electric over hudraulic valves that control chute rotation and chute up and down for distance of throw. Since its hydraulic theres NO shear pins.....none.
I just love not having to mess with those things. I can blow snow for 3-4 hours in a heated cab wearing t shirt and bunny slippers (well....i could but dont wear the slippers).
i never have to touch the snow.
   / Do they make this type of snowblower? #14
Mount an easy-to-find rear blower on the rear, then turn your seat sideways like these guys.
Bruce
   / Do they make this type of snowblower? #15
the control of the chute is done thru a hand grip unit<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=372528"/>
So to disengage the blower you disengage the PTO?
   / Do they make this type of snowblower? #17
I'll just throw this out there for you to chew on. Every now and then the front blowers do come up for sale used. Even if you ended up buying the subframe / quick hitch new, you have several options on finding a used front blower. First, depending on the width you need to cover your tire tracks, you can use the BX blower, the B series blower, and even the big L series blower. They are all made by RAD up in Canada and the nose of the quick hitches are all the same. As an added bonus, RAD also makes , or made, the front blowers for Massey Ferguson and New Holland (as well as Honda and no doubt others)..... so you may find a deal on one in red or blue.
FWIW , I have the B2782 on my B3030 and its a snow munching beast.. The blower is very stout. I have the hydraulic chute rotation as well as the hydraulic chute deflector and its a joy to operate. I have had a rear blower in the past and I wouldn't go back.
   / Do they make this type of snowblower? #19
yes. which is a toggle switch for me
I had always wondered how they worked. It is a cool setup and the power pack opens a lot of options for you.
   / Do they make this type of snowblower? #20
yup, im actually planning on buying a loader mounted trencher soon. i can use this in my business (electrical contractor). It will be powered off the hyd power unit.
2007 GREAT DANE CONVERTER DOLLY (A51222)
2007 GREAT DANE...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
197637 (A50459)
197637 (A50459)
International 574 2wd Tractor (A52128)
International 574...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
