BX 2200 stripped oil bolt
   / BX 2200 stripped oil bolt #11
Thanks to everyone that replied, the accumulated knowledge of men with tractors is something that still astonishes me, I love this forum! Brad
But like everything on the internet remember that EVERYONE is an expert. Take everything you read with a grain of salt.
Now if you get more then one answer one way or the other then that position might have some traction. But always do as much checking as you can before you start on a project you have questions about.
   / BX 2200 stripped oil bolt #14
I was able to just replace the old drain bolt with a new one. That seems to be the easiest fix if it will work.
   / BX 2200 stripped oil bolt #15
I had the same problem on my old BX 2200, and a new drain plug bolt was all it ook.
Will
   / BX 2200 stripped oil bolt #16
Kubota must be smart and make the bolts a tad softer.
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
CASE IH 2555 4R COTTON PICKER (A51247)
CASE IH 2555 4R...
11' CONTAINER (A51248)
2016 KENWORTH T3 TANDEM AXLE REAR LOADER GARBAGE TRUCK (A53426)
2016 KENWORTH T3...
Kubota BX2230D (A47384)
Kubota BX2230D...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
