Loader will not take grease.
/ Loader will not take grease. #1
bckskin2
Member
Washington. IL
New Holland TC30
Some of the zerks on my NH loader would not take grease I tried cleaning around the shaft and that worked on one of them.
Jerry
/ Loader will not take grease. #2
Take the fitting out and see what happens when you put the gun to it. If it won't take any grease, replace the fitting.
/ Loader will not take grease. #3
Make sure there's no load on the joint - or try moving it a bit and try the grease gun again. Sometimes the clearance between inner and outer bores closes up and the grease has no way to fill the joint.
/ Loader will not take grease. #4
Also, on new equipment the clearances may be so tight that it impedes the process. BTDT If the grease is coming out from around the top of the zerk, you might need a new tip on your grease gun. Auto parts stores have them. BTDT too.
Mark
/ Loader will not take grease. #5
Last resort solution is to get someone working the loader up and down or the bucket back and forth depending on which zerks wont take grease while you pound the grease to them.
/ Loader will not take grease. #7
Quick easy solution to get you going quickly. Soak the old zerks in some diesel and they may become usable again.
/ Loader will not take grease. #8
if the joint is moving, and the zerk is good and it won;t take grease.. the grease channel in the pin may have hard grease in it. one of those poundable blockage clearers with some lighter oil in it may help.
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
Demco Lowboy Trailer (A65563)
Demco Lowboy...
Heaven Hill Burbon Barrel (A65583)
Heaven Hill Burbon...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
