New Owner Max 28XL
   / New Owner Max 28XL #11
Wish my Max 22 had the hydraulic thumb.
How is your deck suspended with the backhoe on? Also did yours come with mmm/backhoe/loader all installed from the factory?
Yes, all installed from the factory.
The deck is raised to it's max position and pinned at the rear frame. Since it needs the links installed to raise and lower it, it's fixed at one height. It operates fine if you like your lawn at 4in;) I might design a pair of small actuators to raise and lower it via the pivot points that would usually use the lift arms...who knows...lol, project for another day;)
   / New Owner Max 28XL #14
Thanks. I actually saw that the other day and thought that's what it could be for, just need to take the backhoe off. I'm planning on making a rolling stand for it.
Still have a few projects to do. Armrests and lighting are after the stand.
   / New Owner Max 28XL #15
Hi all - not to hijack thread here, but I too have new Max 28, no MMM but do have BH. It is very probable that I am missing the boat, but I am surprised that the lower (3-point) lift arms must be removed to mount / use BH! Once I cut the zip ties from lower arms I thought Hum.... where's the moutning point for these while BH is on! I even noticed one of our fellow Max 25 friends on here had the lowers and BH on - perhaps the difference between the 25 vs. 28? Am I missing the obvious or have you MAX 28 guys found a creative method!?!? THANKS!
   / New Owner Max 28XL #16
Realize this post is almost 2 years old, but if you're still on TBN, can you provide some more insight on how you groom that driveway? I just got a 26XL with a FEL and box scraper and would appreciate any insights you have on maintaining a long gravel driveway... have a 1/4 mile, sloping and twisting one myself that's fairly rutted from rain the past few years.
   / New Owner Max 28XL #17
   / New Owner Max 28XL #18
I just took delivery of a max26 last month and must be some new stuff. There is a "cross T" if you will that pins to my tow bar for the lift arms to pin too for bh. Mmm height is controlled via the 3 point lift arms
   / New Owner Max 28XL #19
Redinrush, I have not looked at the newer models since I bought my Max 28. Could you post a picture of this cross T. I would like to see if it is something I can add.
Thanks,
Been awhile lol,
Take the tines off the box blade, the key is to use the top link to adjust the box blade for the correct cutting edge pitch. Most will have two cutting edges, one toward the inside of the box facing forward and one trailing edge facing back. Adjust the tilt until the blade on the front facing forward is just slightly above the ground, talking like 1/4in or there abouts. You want the rear blade to do the smoothing. So when it's set up correctly, the front facing cutting edge shaves the high spots and the rear cutting edge smooths and fills the low. Be careful of pushing with the box blade in that position because it will gouge the ground when going in reverse, not to mention it will put a great deal more stresses on the 3-point as it's designed for pulling not as a dozer.
BigRed
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
New Long Forks (A53002)
New Long Forks...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
