Anyone know what this is? Or is part of?
   / Anyone know what this is? Or is part of? #1
Kilo69
Member
Coldstream Nova Scotia Canada
Kioti CK35 HST
Found this out back on the acreage.
No clue what it is, but looks pretty cool
one end looks like a keyed shaft. I was thinking maybe some type of tiller or stump grinder?
   / Anyone know what this is? Or is part of? #2
I'm no farmer, but it looks like a section from some kind of tillage tool. Rotary hoe of some sort...
Lunk
   / Anyone know what this is? Or is part of? #3
Looks like an old head off of a catfish pond aerator.
   / Anyone know what this is? Or is part of? #4
Appears to be driven by a flat belt from a power source, so probably a stationary device.
Bruce
   / Anyone know what this is? Or is part of? #8
It is a spike tooth cylinder from a combine. They also came with rasp bars instead of those spikes. The grain is cut and pulled up the mouth of the combine head into this thrashing cylinder where those spikes turn between a similar set that is mounted stationary on the bottom of the combine. If you remove the gathering head from a combine, you would see this big wheel.
   / Anyone know what this is? Or is part of? #9
Gary is right - it's a spike-tooth cylinder from a grain thrasher. I'd guess from the flat belt pulleys it's actually from a stationary thrasher rather then a combine. I've never seen a combine that used flat belts on small pulleys like that.
Terry
Interesting, would it have any use or just throw it on the scrap metal pile?
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
