Brush killer?
   / Brush killer? #11
Can you spray crossbow on a pasture to kill the weeds and not kill Bermuda grass?
Eddie
   / Brush killer? #12
Can you spray crossbow on a pasture to kill the weeds and not kill Bermuda grass? Eddie
It is a little overkill IMHO to spray over pasture. We only use it to spot spray fence rows, ect. But it is a selective herbicide that targets broadleaf plants so your Bermuda should be fine.
EDIT: I just went over the label to be sure and found no mention of Bermuda.
   / Brush killer? #14
Eddie
Grazon P+D would be a better choice for pastures since it is designed for pastures. Hence the name Grazon (graze on).
   / Brush killer? #15
The problem with Grazon is it is incredibly persistent. The manure of animals fed hay sprayed with Grazon will kill plants.
I've had good luck with brush using a triclopyr/glyphosate blend. Both break down very quickly in the soil.
   / Brush killer? #17
They say goats will clear brush and stuff. Cheap and they fertilize the soil at the same time. HAHA
   / Brush killer? #18
Did the OP say that animals are in the area....I don't remember that, and that is why I suggested it. If you want it dead, this will do it....and IF an animal gets into it the animal will not be harmed.
   / Brush killer? #19
Dozens of brand names out there to represent a mere handful of ingredients or blends. Generics aplenty if you read some labels, so what's in a name? Once you learn the chemicals & their traits (selective or not, carry over or not, etc) you only have to do some math to mix up your concentration.
Learn a few ingredients' characteristics (what they do & don't do), mix %s, and go from there, ... or pay top dollar to have the maker decide for you.
Thanks for the link, tj! We're all somewhere on a learning curve with this stuff ....
   / Brush killer? #20
Please let me know how many goats it takes to clear an acre and how long and what about water?what kind of maintenance I need to plan on for the goats and what I will need to do when everything grows back. Do they eat everything or are they selective. How do you contain and protect them.
40' Sea Container (A50774)
40' Sea Container...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2007 Nissan Sentra 2.0 (A50120)
2007 Nissan Sentra...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
20' Sea Container (A50774)
20' Sea Container...
