Brush killer?
   / Brush killer? #1
JDRandyC
Member
I am trying to kill off woody brush and vines. The stuff I have been using works fairly well but it requires a lot of product per Gallon of mix. ( requires 4 to 8 oz per gallon) so it gets fairly expensive. Don't want to use roundup because I have some grass.
Can anyone recommend a product that works reasonably well and is not too expensive.
Thanks
   / Brush killer? #2
Crossbow. One gallong of concentrate makes 100 gallons ready to use.
   / Brush killer? #3
Another endorsement of Crossbow -- I use a 1.5% mixture (2 ounces per gallon of water) in spraying Chinese privet.
Crossroad is a generic version of Crossbow available at Rural King -- http://www.ruralking.com/crossroad-brush-killer-1-gal-generic-replacement-for-crossbow.html?utm_medium=cse&utm_source=google&CAWELAID=1624235191&CAGPSPN=pla&catargetid=520009190000031013&cadevice=c&gclid=CKWG54n2nL4CFdDm7AodMS4AyQ.
Steve
   / Brush killer? #4
There is an old product that works well I think it is called bil e goat. :laughing: Sorry I just don't like to have poison on me and I bet if you knew how much you actually got on you when you spray it would scare you.
   / Brush killer?
Poison is everywhere Ed, if you look what's in a bottle of shampoo, you'll never wash your hair again.
   / Brush killer? #8
   / Brush killer? #10
   / Brush killer? #11
Can you spray crossbow on a pasture to kill the weeds and not kill Bermuda grass?
Eddie
   / Brush killer? #12
Can you spray crossbow on a pasture to kill the weeds and not kill Bermuda grass? Eddie
It is a little overkill IMHO to spray over pasture. We only use it to spot spray fence rows, ect. But it is a selective herbicide that targets broadleaf plants so your Bermuda should be fine.
EDIT: I just went over the label to be sure and found no mention of Bermuda.
   / Brush killer? #14
Eddie
Grazon P+D would be a better choice for pastures since it is designed for pastures. Hence the name Grazon (graze on).
   / Brush killer? #15
The problem with Grazon is it is incredibly persistent. The manure of animals fed hay sprayed with Grazon will kill plants.
I've had good luck with brush using a triclopyr/glyphosate blend. Both break down very quickly in the soil.
   / Brush killer? #17
They say goats will clear brush and stuff. Cheap and they fertilize the soil at the same time. HAHA
   / Brush killer? #18
Did the OP say that animals are in the area....I don't remember that, and that is why I suggested it. If you want it dead, this will do it....and IF an animal gets into it the animal will not be harmed.
   / Brush killer? #19
Dozens of brand names out there to represent a mere handful of ingredients or blends. Generics aplenty if you read some labels, so what's in a name? Once you learn the chemicals & their traits (selective or not, carry over or not, etc) you only have to do some math to mix up your concentration.
Learn a few ingredients' characteristics (what they do & don't do), mix %s, and go from there, ... or pay top dollar to have the maker decide for you.
Thanks for the link, tj! We're all somewhere on a learning curve with this stuff ....
   / Brush killer? #20
Please let me know how many goats it takes to clear an acre and how long and what about water?what kind of maintenance I need to plan on for the goats and what I will need to do when everything grows back. Do they eat everything or are they selective. How do you contain and protect them.
iDrive TDS-2010H...
(4) UNUSED FORERUNNER 12-16.5 TIRES (A60430)
(4) UNUSED...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61306)
2023 Kubota...
2020 Deere 50G (A53317)
2020 Deere 50G...
KUBOTA M7040 TRACTOR (A60430)
KUBOTA M7040...
