I finally get it up, now i can't get it down!!
   / I finally get it up, now i can't get it down!! #1
Tem9762
Western New York
Kubota B7800
That's right, my Bri-Mar dump trailer won't go down. It's a gravity down system but when I hit the button, Nothing! My understanding is there is a solenoid that allows the fluid to return. Any ideas/tricks??
Thanks
   / I finally get it up, now i can't get it down!! #2
I would check for blown fuses first...then if no joy find the solenoid servo and manually move the valve...
   / I finally get it up, now i can't get it down!! #3
Are the hinges well lubricated??? A little rust will hold those box up there!!!!
   / I finally get it up, now i can't get it down!! #4
I don't think that your supposed to take more than 1 of those pills!:eek:
   / I finally get it up, now i can't get it down!! #5
I was waiting for that.:)
   / I finally get it up, now i can't get it down!! #7
And seek medical attention if it stays up more than 4 hours.
   / I finally get it up, now i can't get it down!! #8
I think I would be seeking something other than medical attention.....
Chris
   / I finally get it up, now i can't get it down!! #9
As you check it out with the bed up MAKE SURE YOU BLOCK THE BED before getting under it!
I met a one legged guy that climbed over a frame rail to work on a dump truck rearend.
The bed had been up all weekend and when he climbed on it was monday morning and it dropped!
If it has a solenoid you might be able to hear it click if it is working.
Has it been more than 4 hours?
4 Hours!! It's been four days!!!!!!!! I don't think I need to see a Dr. , I think I need to get admitted,,,,,,,,, Turns out it was the hinges. Originally checked them to see if stones or something got lodged
in there. Took a couple of guys putting some weight on it to get it to move,, Never would have thought rust could stop that weight.
Thanks for the help and laughs!
TANK MANIFOLD (A55745)
2003 International 7400 T/A Heil 12 Yard Dump Truck (A55852)
2003 International...
2005 PETERBILT 379 TANDEM AXLE SLEEPER (A56138)
2005 PETERBILT 379...
CASE CX330 EXCAVATOR (A52707)
CASE CX330...
2005 IC Corporation PB105 School Bus (A54814)
2005 IC...
2021 John Deere R4038 Sprayer (A53485)
2021 John Deere...
