Need paint to touch up my ratchet rake
   / Need paint to touch up my ratchet rake #1
jodebg
New Hartford, CT
Kubota B-2650
Anyone know what spray paint to use to match the
yellow color used by ratchet rake?
I called RR and they told me JD Yellow.
Bought that and it was much to light.
RR uses a yellow that is a good match to
Dewalt power tools yellow.
   / Need paint to touch up my ratchet rake #2
If it is that important to you why not go to the paint store and match it to a color swatch.
   / Need paint to touch up my ratchet rake #3
You could try rustoleum industrial yellow. I think TSC also sells an industrial yellow.
   / Need paint to touch up my ratchet rake #4
The paint you have will work very well if you paint the whole RR. Why try to match?
Bruce
   / Need paint to touch up my ratchet rake #5
Since you have a Kubota why not paint it Kubota Bright Orange II.
   / Need paint to touch up my ratchet rake #6
Why are you worried about touching up the paint on something that is essentially the cutting edge on a loader bucket?
   / Need paint to touch up my ratchet rake #7
I think it's the JD "industrial" yellow used on construction equipment, not what's used on the green and yellow tractors. Probably a tough find local other than a JD dealer. But I agree with the others, why worry about it?
   / Need paint to touch up my ratchet rake #8
I used Cub Cadet "High-Performance Maintenance" paint. Cadet Yellow - 759-3258. It's a good paint and a good match. The only reason I did a touch-up was because I had my 6-ft RR cut down to fit my 5-ft bucket and the two outermost tabs needed to be welded back on to the rake. I primed and painted just the cut/welded areas.
   / Need paint to touch up my ratchet rake #9
Kenny, you know I have found the Deere construction yellow to be pretty good paint. Used it to coat my manlift attachment several years ago and it is holding up well.
   / Need paint to touch up my ratchet rake #10
Some things I will touch up others no. If it's job makes it come into contact with dirt as part of its job then I don't worry about it.
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
