Need paint to touch up my ratchet rake
   / Need paint to touch up my ratchet rake #1
jodebg
New Hartford, CT
Kubota B-2650
Anyone know what spray paint to use to match the
yellow color used by ratchet rake?
I called RR and they told me JD Yellow.
Bought that and it was much to light.
RR uses a yellow that is a good match to
Dewalt power tools yellow.
   / Need paint to touch up my ratchet rake #2
If it is that important to you why not go to the paint store and match it to a color swatch.
   / Need paint to touch up my ratchet rake #3
You could try rustoleum industrial yellow. I think TSC also sells an industrial yellow.
   / Need paint to touch up my ratchet rake #4
The paint you have will work very well if you paint the whole RR. Why try to match?
Bruce
   / Need paint to touch up my ratchet rake #5
Since you have a Kubota why not paint it Kubota Bright Orange II.
   / Need paint to touch up my ratchet rake #6
Why are you worried about touching up the paint on something that is essentially the cutting edge on a loader bucket?
   / Need paint to touch up my ratchet rake #7
I think it's the JD "industrial" yellow used on construction equipment, not what's used on the green and yellow tractors. Probably a tough find local other than a JD dealer. But I agree with the others, why worry about it?
   / Need paint to touch up my ratchet rake #8
I used Cub Cadet "High-Performance Maintenance" paint. Cadet Yellow - 759-3258. It's a good paint and a good match. The only reason I did a touch-up was because I had my 6-ft RR cut down to fit my 5-ft bucket and the two outermost tabs needed to be welded back on to the rake. I primed and painted just the cut/welded areas.
   / Need paint to touch up my ratchet rake #9
Kenny, you know I have found the Deere construction yellow to be pretty good paint. Used it to coat my manlift attachment several years ago and it is holding up well.
   / Need paint to touch up my ratchet rake #10
Some things I will touch up others no. If it's job makes it come into contact with dirt as part of its job then I don't worry about it.
71050 (A49346)
71050 (A49346)
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
