HELP I NEED Jacobson center deck pully for HR 15
   / HELP I NEED Jacobson center deck pully for HR 15 #1
randy111
ravenna ohio
jacobsen hr15
Does anyone know where i can get a center deck pully for a Jacobson HR 15 Jacobsen part #163716
It appears jacobson does not make anymore.
Thanks Randy
   / HELP I NEED Jacobson center deck pully for HR 15 #2
Randy, are the splines alright on the pulley? If so, a machine shop could weld into a new sheave. Likewise, if the splines are bad, count the splines and measure the shaft diameter to determine a replacement that could be welded in the sheave.
   / HELP I NEED Jacobson center deck pully for HR 15 #3
Thanks Randy
If the pulley grooves are still good, the center splined area is replaceable from Jacobsen. I just bought 3 of them a month ago. I can get you the part number if needed.
   / HELP I NEED Jacobson center deck pully for HR 15 #4
Can you forward the part number for Jacobsen Mower Drive Pulley center spline replacement?
Thanks,
DJ in Maryland 301-247-2193
   / HELP I NEED Jacobson center deck pully for HR 15 #5
Thanks,
I have an early serial number between 1601 and 3700. The pulley part number is 163252(obsolete), the center spline replacement is # is 337998. If you have the later machine( serial # 3701 and up) which uses the 163716 pulley, it uses a different spline. I think it is 338701 but Call Jacobsen Technical at 1-800-848-1636 and they can look it up and verify.
Hope this helps.
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
